What is the difference between the gsr and ls oil pump...i couldnt find one
Old Sep 10, 2003 | 10:28 AM
philipwight's Avatar
Default What is the difference between the gsr and ls oil pump...i couldnt find one
i took apart both a ls and gsr oil pump to see if there was a visible difference.....i couldnt find one. The only thing that is could think of being different is the spring. But even that felt to be the same(not a real accurate measurement). Here are some pics......
the gsr oil pump is to the left
this is close up of an ls oil pump
this is gsr
Old Sep 10, 2003 | 10:41 AM
mmuller's Avatar
Mad Scientist
Default Re: What is the difference between the gsr and ls oil pump...i couldnt find one (philipwight)
cant remember from the top of my head what the flow differences were, but the springs have different pressures, the gsr one is stiffer, thus aloowing higher pressure
Old Sep 10, 2003 | 10:46 AM
Default Re: What is the difference between the gsr and ls oil pump...i couldnt find one (mmuller)
ok that is understandable but why are some people saying it flows more at the same pressure?
Old Sep 10, 2003 | 11:06 AM
mmuller's Avatar
Mad Scientist
no it just has more pressure.
But newer pumps all flow the same
Old Sep 10, 2003 | 11:25 AM
so all that is different is the spring. I wish you could buy just the spring fropm the dealer.
Old Sep 10, 2003 | 11:28 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philipwight &raquo;</TD></TR><TR><TD CLASS="quote">so all that is different is the spring. I wish you could buy just the spring fropm the dealer. </TD></TR></TABLE>
you can:
http://www.acuraautomotivepart...y.jsp
Old Sep 10, 2003 | 11:37 AM
NICE! well that it cool. Thanks.
That will get my ls/vtec one step closer. I dont want to use my gsr oil pump because that will be running soon.
Old Sep 10, 2003 | 08:50 PM
T4eg's Avatar
yes the gsr pump flows more volume at the same pressure
Old Sep 10, 2003 | 10:22 PM
mmuller's Avatar
Mad Scientist
Default Re: What is the difference between the gsr and ls oil pump...i couldnt find one (BlueHatch00)
B18C and B18C5 are 71 liters/min, B18B's are 50 litres/min.
96-up all the same
the only difference is the spring
Old Sep 11, 2003 | 11:38 AM
fox297's Avatar
Are there any differences in the gear like # of teeths, size, shape, etc? Why do people sell aftermarket gears?
Old Jan 28, 2004 | 12:14 AM
kool168's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">B18C and B18C5 are 71 liters/min, B18B's are 50 litres/min.
96-up all the same
wut about B16A oil pump?
Old May 5, 2004 | 04:46 AM
XDEep's Avatar
Default Re: What is the difference between the gsr and ls oil pump...i couldnt find one (Sol-R)
interesting thread. any updates?
which model pumps are we supposed to upgrade to exactly? some have the same part numbers..
Old May 5, 2004 | 06:22 AM
spaceman's Avatar
Default Re: What is the difference between the gsr and ls oil pump...i couldnt find one (XDEep)
i got a type-r from an integra for my b16,i was told that it will work..i havnt tried installing it yet..i know some have different size gears like 80mm to 84mm or something like that...
Old May 5, 2004 | 07:43 AM
Dan GSR's Avatar
I just looked up the part numbers in my electronic parts catalog for the spring, and they are all the same
Old May 5, 2004 | 07:44 AM
Dan GSR's Avatar
Default Re: What is the difference between the gsr and ls oil pump...i couldnt find one (fox297)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox297 &raquo;</TD></TR><TR><TD CLASS="quote">Are there any differences in the gear like # of teeths, size, shape, etc? Why do people sell aftermarket gears?</TD></TR></TABLE>
the stock oil pump gear is made out of a brittle metal
the aftermarket pieces are much more durable
Old May 5, 2004 | 07:49 AM
mmuller's Avatar
Mad Scientist
Default Re: What is the difference between the gsr and ls oil pump...i couldnt find one (Dan GSR)
yeah, all the parts #'s are the same, because all newer oil pumps are the same.
flow differences existed in the older obd1 ones
Old May 5, 2004 | 08:28 AM
spaceman's Avatar
when you go to todaracing.com and look at there oil pump gears they ask you to measure the gears to make sure you get the correct parts..
Old May 5, 2004 | 10:27 PM
JDMorgan's Avatar
isnt one 80mm and the other like 2 or 4mm differant in size? i think aftermarket companies sell 2 sizes.
Old Dec 19, 2004 | 10:35 AM
javenger's Avatar
so if i just order just the spring, my ls oil pump will performe like a gsr oil pump?
Old Dec 19, 2004 | 05:56 PM
PrettyLude's Avatar
no
Old Dec 19, 2004 | 08:03 PM
LSvtec03's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by javenger &raquo;</TD></TR><TR><TD CLASS="quote">so if i just order just the spring, my ls oil pump will performe like a gsr oil pump?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">no</TD></TR></TABLE>
if the spring is the only difference, then why not?
Old Dec 19, 2004 | 10:13 PM
incredteg3's Avatar
Default Re: (LSvtec03)
ahhhh someone with real knowledge please give a response and the reason why. i want to know what to use for my ls turbo. I have a stock ls pump, it will be replaced either by a new obd 1 ls/gsr/type r depending on the advantages or disadvantages.
some one who can back up there knowledge
Old Dec 20, 2004 | 01:54 AM
untitled's Avatar
Default Re: (incredteg3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incredteg3 &raquo;</TD></TR><TR><TD CLASS="quote">ahhhh someone with real knowledge please give a response and the reason why. i want to know what to use for my ls turbo. I have a stock ls pump, it will be replaced either by a new obd 1 ls/gsr/type r depending on the advantages or disadvantages.
some one who can back up there knowledge </TD></TR></TABLE>
I agree this is a very interesting thread. If i knew all i needed to buy was a spring, i would be alot happier.
So early ls oil pumps just need the high psi spring that comes in pre-96 gsr's and all bseries after 96. Correct?
Old Dec 21, 2004 | 10:50 AM
LSvtec03's Avatar
Default Re: (untitled)
bump?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">if the spring is the only difference, then why not?</TD></TR></TABLE>
phyzJunkieCivic
Aug 24, 2006 10:27 PM
Turbo_TONY
Jul 26, 2006 11:32 AM
kasso
Aug 7, 2005 02:31 PM
se93
Apr 8, 2002 05:23 PM
