GETTING A SQUEEK WHEN CLUTCH IS DEPRESSED, HELP!!!!!
My 2000 ;Lude has about 79K now. recently it has been sqeeking whenever I depress the clutch pedal. Is there something at the pedal or along the line to the clutch that can be lubricated to get rid of this annoying noise?? Recently had the clutch master cyl replaced. I'm hoping this is not an expensive fix
What can I do??
What can I do??
pull off slave cylinder boot
spray ball and pivot with lithum grease
work it in by depressing clutch til sound goes away
THANKS
I was hoping it would be an inexpensive fix.
Oh, and yes, my clutch does get depressed some times, as well as my brakes (but you can't blame them really we do take advantage of them
there's a clutch pedal spring in there that does that...all preludes have that problem, at least that's what i've heard...easy fix...new spring
