Does anyone know how to remove the pins in the injector clips?
Old Sep 9, 2003 | 09:21 PM
seanb18c1's Avatar
Default Does anyone know how to remove the pins in the injector clips?
Has anyone done this?
I have the pin removeal tools, I just don't know how to use them. I'm afraid of breaking the connectors.
Thanks
Old Sep 9, 2003 | 10:29 PM
mmuller's Avatar
Mad Scientist
Default Re: Does anyone know how to remove the pins in the injector clips? (seanb18c1)
i use a screwdriver and needle pliers , one to move the little leg out and the other to pull the clip out.
Dont be squeeerd
Old Sep 10, 2003 | 07:56 AM
T4eg's Avatar
Default Re: Does anyone know how to remove the pins in the injector clips? (mmuller)
use a small screwdriver and push one side of the clip around to where it says back by itself. Then pull up on the harness and remove the other side of the clip
Old Sep 10, 2003 | 12:44 PM
seanb18c1's Avatar
Can either of you guys please post a pic of where i'm supposed to push?
Thanks
Old Sep 10, 2003 | 08:18 PM
PHiZ's Avatar
Default Re: (seanb18c1)
get a jewellers screwdriver, and just figure it out.
It's not hard.
-PHiZ
Old Sep 10, 2003 | 10:20 PM
fuccarlos's Avatar
on the top of the clip there is a piece of rubber insulation with a piece of plastic in it you have to remove this in order to get the pins out gently pry rubber out with a pick
rabshakah
Apr 15, 2015 07:32 PM
bk7794
15
Oct 10, 2011 02:51 PM
giff74
Mar 19, 2005 02:09 AM
Kato7997
Sep 26, 2002 10:25 PM
