torquing motor mount screws?
Old Sep 9, 2003 | 05:53 PM
weakGOODJunKieS.com's Avatar
Default torquing motor mount screws?
my friend and i installed a j's racing engine damper and now the motor makes more noise than before. are we suppose to torque the nuts? if so how many lbs?
Old Sep 9, 2003 | 06:02 PM
eg_nezay's Avatar
Default Re: torquing motor mount screws? (FrostWhiteDC4)
I didnt use torque numbers, just tightened it.
Where is the noise coming from?Did you place the washer in the right place?
Check the dampers bolt to see if its hitting the strut tower.
Old Sep 9, 2003 | 06:06 PM
Default Re: torquing motor mount screws? (eg_nezay)
it sounds like the entire motor is rattling. if i remember correctly, he could feel his steering wheel shake while idle.
this mod was done a while ago, but im asking now to help him out. thanks
Old Sep 9, 2003 | 06:31 PM
eg_nezay's Avatar
Well, if its been a while, he might have a busted mount(driver side). Since that damper only seems to stiffen up one side(pass.side).
Old Sep 12, 2003 | 06:45 AM
jdkindle's Avatar
it creates vibration due to the added stiffness.............so that may be normal
have you tried pinpointing the noise? It could be the hood rattling or something..........mine does that
jdm_DC2R
Jun 9, 2007 01:43 PM
EastSideRider
May 17, 2007 09:28 AM
Cyber ITR
Jan 2, 2004 02:02 AM
