2 headgaskets???????
On my LS/VTEC can I run 2 headgaskets? I have a mugen 2 layer and a stock 3 layer. With the CTR pistons and the fact that I had the head milled .007 to .008 a while ago. When I clayed the motor there was not much clearance. What can I do, and also where can I get thicker headgaskets?
if u really wanna do i right get ur block o-ringed and get a copper gasket made to what u want they have alot of thicknesses
http://www.scegaskets.com/pdf/pg%2047-51.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoKSiR »</TD></TR><TR><TD CLASS="quote">where can I get thicker headgaskets?</TD></TR></TABLE>
Toda or Cometic.
Toda or Cometic.
I had my block decked .010 and the head milled down to the mill mark and I'm running 11.0:1 flat top pistons that poke out of the block, so I took the stock gasket apart and used the 2 outer laters and an SCE .043" copper gasket and that is working just fine, no leaks.....knock, knock.
DB2#308
May 17, 2004 11:54 PM
