put on aftermarket steering wheel and now blinker doesnt turn off?
Old Sep 9, 2003 | 05:17 PM
cjames235's Avatar
Default put on aftermarket steering wheel and now blinker doesnt turn off?
is this typical or did i screw somethin up? what do i need to check for if i did somethin wrong? thanks for any help
Old Sep 9, 2003 | 05:23 PM
EleanoR's Avatar
Default Re: put on aftermarket steering wheel and now blinker doesnt turn off? (cjames235)
yep it shouldn't work. didn't work when i put on my Sparco. i don't know exactly why but i think the stock steering wheel probably has some mechanism that makes it turn off when you complete the turn. i am not totally sure on this
Old Sep 9, 2003 | 05:26 PM
B2FiNiTY's Avatar
Your totally fine.
Old Sep 9, 2003 | 05:27 PM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjames235 &raquo;</TD></TR><TR><TD CLASS="quote">is this typical or did i screw somethin up? what do i need to check for if i did somethin wrong? thanks for any help</TD></TR></TABLE> it has these little notches.. (the stock hub) when i installed my fg360 the same thing happens. it looks like these "notches" however can be put onto an aftermarket hub, which i will try as soon as i get my car back.
Old Sep 9, 2003 | 05:30 PM
nekkedR's Avatar
Default Re: put on aftermarket steering wheel and now blinker doesnt turn off? (Threatcon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote"> it looks like these "notches" however can be put onto an aftermarket hub </TD></TR></TABLE>
it works with my momo
Old Sep 9, 2003 | 05:57 PM
cjames235's Avatar
Default Re: put on aftermarket steering wheel and now blinker doesnt turn off? (nekkedR)
thanks for the replys. ill check it out tomorrow and see if i can make it work. thanks again
Old Sep 10, 2003 | 07:37 AM
cjames235's Avatar
ok im looking at the back of the stock wheel and i dont see any notches to put onto the aftermarket hub. the back of the stock hub it just flat? where are these notches supposed to be?
Old Sep 10, 2003 | 08:36 AM
Dropspeed's Avatar
You have the wrong hub, The correct hub will have the 2 notches that fit into the stock blinker return.
Mattj
jhonda239
14
Jul 12, 2008 07:03 AM
totsie7944
Jan 29, 2008 04:23 PM
Reza^
Jul 19, 2007 12:05 PM
COMplex.
Honda Civic (2006 - 2015)
14
Jan 4, 2007 03:07 PM
