Problem with the gas pumps.
Old Sep 9, 2003 | 02:32 PM
MK Ultra's Avatar
Default Problem with the gas pumps.
I've noticed a problem at certain filling stations. Sometimes the pump does not shut off automatically, causing fuel to spew out the filler neck when the tank is full.
The problem occurs most frequently at new stations or stations with new pumps.
Now ordinarily I would simply avoid stations where the problem occurs, however since I only use Chevron fuel and many of the older Chevrons in convenient locations are closing down, I am usually forced to fill up at one of the stations where this seems to happen most frequently.
My question is if this problem I'm running into is a result of malfunctioning emissions equipment, possibly something to do with the EVAP canister. If the problem is related to my car in some way I'd like to rectify it quickly.
If not, Chevron needs to know that their ******* pumps are defective.
Old Sep 9, 2003 | 02:35 PM
Cosworth's Avatar
Default Re: Problem with the gas pumps. (MK Ultra)
I don't think it's your car. Must be the new pumps.
off-topic, but I've noticed that I get better gas mileage with new Shell gas. At least 25 miles more per tank.
Edit: Zyg
Old Sep 9, 2003 | 02:37 PM
SoCal ITR's Avatar
Default Re: Problem with the gas pumps. (Cosworth)
I doubt it's your car.
Old Sep 9, 2003 | 03:04 PM
Nishant's Avatar
Default Re: Problem with the gas pumps. (zyg)
i think he said "At least 25 miles more per tank."
Old Sep 9, 2003 | 03:41 PM
SoCal ITR's Avatar
Default Re: Problem with the gas pumps. (swtxaznrac3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swtxaznrac3r &raquo;</TD></TR><TR><TD CLASS="quote">i think he said "At least 25 miles more per tank."</TD></TR></TABLE>
That might be what he meant
Old Sep 9, 2003 | 04:04 PM
RTW DC2R's Avatar
do u leave the car running? sometimes I cant even fill mine up all the way if the car is running.
Old Sep 9, 2003 | 05:35 PM
MK Ultra's Avatar
Default Re: Problem with the gas pumps. (RTW DC2)
No. I always shut off the motor.
In fact, I almost got into a fight last year with some guy at a gas station who wouldn't shut his car off while he was fueling it.
Old Sep 9, 2003 | 10:25 PM
STOLEN - ITR 98-0652's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MK Ultra &raquo;</TD></TR><TR><TD CLASS="quote">No. I always shut off the motor.
In fact, I almost got into a fight last year with some guy at a gas station who wouldn't shut his car off while he was fueling it. </TD></TR></TABLE>
I remember Yack fueling his hatchcrap with the motor running... and people freaking out.
It's gasoline, not acetelyne.
But, I suspect both the benefits gained from keeping the motor running (90-odd% of wear at start-up, don't you know?) and the risk of fire are both pretty small.
Anyway - more on topic... I find if I remove the nozzle about half-way through the fueling process and reinsert, that won't happen. If you're fueling on a warm, empty tank, the vapor in there causes it to pressurize as the fuel level rises - it's that pressure that causes the shutoff not to work and then spews gas.
Old Sep 10, 2003 | 12:24 AM
HYREV2NR's Avatar
Find a way to talk to the Manager. Tell them whats happening & if they don't fix it, I would seek some higher authority. It's a SERIOUS safety hazard!!! It's not your car. The "kick-off" on the pump is set incorrectly. If they don't fix it it's a violation of safety codes for all gas pumps.
Old Sep 10, 2003 | 12:38 AM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zyg &raquo;</TD></TR><TR><TD CLASS="quote">Thanks Chris.
What are you doing the first week of Oct? </TD></TR></TABLE>
Yea... umm my first thought would be classes, but nothing major because it'll only be the second week... planning a little trip??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98-0652 &raquo;</TD></TR><TR><TD CLASS="quote">I remember Yack fueling his hatchcrap with the motor running... and people freaking out.</TD></TR></TABLE>
Not to mention the car was running from coast to coast non-stop... including refills..
Steeve_Civic
Dec 10, 2013 12:58 PM
bb2_guy
May 15, 2007 09:10 PM
VTsullyman
Jul 12, 2005 07:57 AM
