Spoonsports Air Cleaner ?
Old Aug 20, 2001 | 08:49 AM
Keane Rated R's Avatar
Default Spoonsports Air Cleaner ?
is it any good? better then K&N? slight increase in power? thanks.
Old Aug 20, 2001 | 09:16 AM
eg6ajk's Avatar
Default Re: Spoonsports Air Cleaner ? (Integra Rated R)
not much can be gained from either one...i would go with K&N, since can be washed and seem to last longer then foam filters....
Old Aug 20, 2001 | 09:18 AM
Kengs's Avatar
Spoon filter is made by Monster Sport; the Power Filter 2 is RED whereas the Spoon is YELLOW. The Monster Sport will be cheaper.
If I remember correctly, Monster Sport claims the Power Filter 2 is one of the best flowing filters on the market.
Old Aug 20, 2001 | 09:34 AM
Jason's Avatar
Default Re: Spoonsports Air Cleaner ? (kengs)
every manufacturer claims their product is the best...wouldn't sell too well if they said..."well it's not as good as the K&N, but..."
#'s talk
[Modified by typer98, 1:34 PM 8/20/2001]
Old Aug 20, 2001 | 10:32 AM
RagingAngel's Avatar
Default Re: Spoonsports Air Cleaner ? (typer98)
I'm not sure how representative my comment will be but I tested the Spoon Sports filter back in '98 and I didn't see much of a gain.
This was on a STOCK '97R with timing advanced to 18deg. I saw 164whp and 117ft-lb of torque.
With the Spoon filter I saw about 2-3 at the Xover and less than 2 at peak.....Torque seemed marginally better but didn't break 4ft-lbs anywhere....
In all fairness I don't think the STOCK setup/exhaust/motor is actually pulling enough air to make a difference with a drop in..... perhaps when you have done all the I/H/E & maybe some cams?
But on the flipside I saw nearly 7whp PEAK gain and ALMOST 9 mid? with my AEM....needless to say, I'm sure you know what I'm still running today....
Old Aug 20, 2001 | 10:37 AM
Flux's Avatar
Default Re: Spoonsports Air Cleaner ? (RagingAngel)
How do these compare to the Comptech foam filter so many of us are using?
Old Aug 20, 2001 | 10:27 PM
AJ PwR's Avatar
Spoon offers this filter for more torque and mid-range response. It bascially doesn't have a big increase to a stock engine compare to AEM but with big cams like Toda B, I don't see AEM does any better then Spoon and actually peak power is a bit higher with the Spoon filter. What I can say is , all depends with your setup.
Chris Cage
Mar 1, 2005 02:44 PM
REDTOPAlchemy
Jul 29, 2004 10:58 AM
-Whitey-
Dec 2, 2002 06:10 PM
Integra_B18B
Sep 22, 2001 10:17 PM
