92+ lude brakes on 94+ accord???
Who has done this brake converison and what needs done to do it??
I've got the 92 lude spindles, but the lower ball joints are different and cannot be interchanged to work. is there a certain ball joint u can use?? help me!$#@
nevermind i guess.. . . i got the lower control arm and the radius rod, then had to get new tie-rod ends and stuff like that....in all honesty, it's not worth it. if you are going to upgrade, i'd go big. . .like nsx brakes or something.
search, use CL hub to get prelude style (rotor over hub) brake rotors.
the prelude hub wont work on the accord bearing. The prelude suspension arms are too different to make work.
