Potencial of a B16a all motor ....does it have any?
Old Sep 9, 2003 | 10:51 AM
SiB16A's Avatar
Default potential of a B16a all motor ....does it have any?
Modified by SiB16A at 11:39 PM 1/22/2008
Old Sep 9, 2003 | 10:55 AM
bossman032's Avatar
Default Re: Potencial of a B16a all motor ....does it have any? (SiB16a)
it can be fast it can be slow.
the key is how much money you willing to SPEND!!!
edit: most people don't like b16a because of the block its 1.6 not much torque but if you have the money you can make a b16a fast!!!
Old Sep 9, 2003 | 10:56 AM
Phatwhippin_CRX's Avatar
Default Re: Potencial of a B16a all motor ....does it have any? (bossman032)
exactly....
Some Toda C spec cams, indiv. throttle bodies, etc........ it adds up. But revving out to 10-11k on a fully built 1.6L has to be quite insane, if you have the cash
Old Sep 9, 2003 | 11:47 AM
roadawg's Avatar
Of course it has potential, why wouldn't it?
It's only 1595 cc's, but the bottom end will rev as high as te top end will. And if you have stage 2 or 3 cams with 11.1 or more compression you will make serious power. If you had I/H/E, (a good header), bigger TB, ITR manifold, stage 2 or 3 cams, and Hondata the engine will be pushing lots of WHP.
The guys with the b18's and b20 talk smack because their motors are bigger and it's easier to make power with a b18, or b20. The b16 has potentail but a bigger motor has even more potential to make 200 + WHP, which is very rare for a b16.
Old Sep 9, 2003 | 11:51 AM
NathanMorris's Avatar
Default Re: Potencial of a B16a all motor ....does it have any? (SiRWanabe)
potential in any motor really...with enough cash, but the b16 will cost a lot to get moving....the reason they talk smack...well, it's more rare to see a fast b16 ...because it takes a lot more money and technical know-how than a fast b18.
- Nathan
Old Sep 9, 2003 | 12:09 PM
Default Re: Potencial of a B16a all motor ....does it have any? (92Lx)
It's more rare to see a fast B18a/b than it is to see a fast B16a.......
Old Sep 9, 2003 | 12:37 PM
SiB16A's Avatar
Default Re: Potencial of a B16a all motor ....does it have any? (Phatwhippin_CRX)
Thanks all .....Do i have to raise my compression for stage 2 skuck 2 cams or can i keep my stock bottom end
Old Sep 9, 2003 | 12:45 PM
SiRex91's Avatar
Here you go: https://honda-tech.com/zerothread?id=604024
Old Sep 9, 2003 | 02:50 PM
SimbaDogg's Avatar
Default Re: Potencial of a B16a all motor ....does it have any? (SiRex91)
resleeve the block, make it a 1.75 liter w/ a perfect r/s ratio...thats what i call P-I-M-P
HondachrisEJ1
Dec 10, 2007 09:00 PM
christ0pher
Jul 17, 2007 12:09 PM
kenepo_vtec
May 11, 2004 08:36 PM
mannyman
22
Feb 22, 2002 10:44 AM
