is it bad to plug up vacuum hoses?
Old Sep 9, 2003 | 09:01 AM
F120man's Avatar
New User
Default is it bad to plug up vacuum hoses?
i got a h22 swap into a eg, there aer some loose hoses that is vacuum. i was wondering if i can just use some screws or tape to plug up the vacuum. is this recommended?
Old Sep 9, 2003 | 09:02 AM
Greyout's Avatar
Default Re: is it bad to plug up vacuum hoses? (F120man)
ideally you would remove the line entirely and use a vaccum cap (you can get a box of different colors and sizes for like $2).
but as long as whatever you plug it with isn't going to get sucked in, you're fine.
Old Sep 9, 2003 | 10:24 AM
Old_Nocturnal's Avatar
Only bad if they leak
Old Sep 9, 2003 | 10:34 AM
LudeyKrus's Avatar
Default Re: is it bad to plug up vacuum hoses? (Nocturnal)
it's fine; just try to take it off at the nipple, like mentioned above; it'll clean things up much better.
Old Sep 9, 2003 | 12:59 PM
F120man's Avatar
New User
Default Re: is it bad to plug up vacuum hoses? (LudeyKrus)
how bout electric tape? thats what ive been using so far.
brokenojoke
22
Apr 23, 2012 03:33 AM
Linh.
Aug 12, 2006 12:17 AM
importfanatic17
Apr 25, 2006 07:30 PM
95BlkGSR
Jun 23, 2005 11:27 PM
Andrew 825SM
Dec 4, 2002 05:54 PM
