Are all non-vtec b series dizzys the same?
Old Sep 8, 2003 | 07:50 PM
jetpilot's Avatar
Default Are all non-vtec b series dizzys the same?
i need a dizzy for my B18B1, can i use anyone from any Bseries, either vtec or non vtec? or just the non vtec ones like B18A, B20Z, etc? THANKS
Old Sep 9, 2003 | 07:25 AM
DevinW's Avatar
Default Re: Are all non-vtec b series dizzys the same? (jetpilot)
I'm pretty sure you'll need one to match the year of your engine from a non-VTEC, if your engine is non-VTEC. We had a 96 Civic harness and had to switch plugs to make it fit the '99 B20 distributor.
I don't believe you can swap vtec/non-vtec dizzys.
Old Sep 10, 2003 | 01:40 PM
Doodoo's Avatar
I know for a fact there is a difference in the housings between the 90-91, 92-93, and 94-up HOUSINGS. You must find the bolt pattern that matches your head.
Internally the 90-91(non-OBD) is different from the 92-95(OBD-1).
raverx3m
Aug 29, 2012 11:09 AM
accord2civic2prelude
Aug 8, 2009 02:18 PM
turbob16ef
Aug 23, 2005 12:40 PM
powerslide360
May 15, 2004 08:52 PM
hoggy
Mar 31, 2004 10:29 AM
