Studder, and shake below 1800 rpm
Old Sep 8, 2003 | 07:30 PM
blackcivicsi's Avatar
Default Studder, and shake below 1800 rpm
When I start out like normal driving. If I don't rev to abot 1800 to 2000 rpm my engine will studder and shake. Kind of feels like wheel hop. So I took it to the dealership and they drove it and they said that is where you have to rev it inorder to have a smooth start.Does any of this sond normal????
I have a 00' Civic Si
Old Sep 8, 2003 | 08:06 PM
Stripped Honda's Avatar
99-0104
Default Re: Studder, and shake below 1800 rpm (blackcivicsi)
my 96 ex does the same thing but i have a bad rear motor mount
Old Sep 9, 2003 | 12:57 AM
If I just start out at 2000 rpm will it hurt the clutgh all that bad?
Old Sep 9, 2003 | 07:13 AM
Crazydave's Avatar
Default Re: (blackcivicsi)
look for a vacuum leak
Old Sep 9, 2003 | 07:42 AM
I'll do that.Do you think it will hurt the clutch real bad ubtil I find the problem?
Old Sep 9, 2003 | 08:41 AM
3gdude's Avatar
Sounds like clutch chatter to me. Does it do it if you dont give it any gas and just slowly let up clutch, like you would if you were creeping in traffic ??....3gdude
Old Sep 9, 2003 | 10:02 PM
Will starting out a 2000 rpm hurt the clutch real bad?
Old Sep 9, 2003 | 10:33 PM
masterminds's Avatar
check your spark plugs,and then the distributor ,could be a loose wire in it so look inside it
ferio-ichi3
Apr 29, 2015 09:32 AM
toofatt
10
Dec 4, 2014 03:27 PM
Ideal R
Nov 26, 2001 01:24 PM
