Squeak sound
Old Aug 19, 2001 | 10:49 PM
Type Goch's Avatar
New User
Default Squeak sound
it seems like these days, ive been noticing this squeak sound coming from the wheel area...the squeak goes along with the rotation of the wheels...i can hear it at low speeds, any ideas what this might be?
Old Aug 19, 2001 | 11:22 PM
Wet Nudl's Avatar
New User
Default Re: Squeak sound (Type Goch)
The first thing I will do is rotate the front tire to the rear (the side that squeaks) just to check it's not the tire/wheel itself. Other than that, I can only think it's the suspension bushing..
Old Aug 19, 2001 | 11:29 PM
SMSP's Avatar
One squeak per rotation? Pull the wheel and look at your brake pads. There is a piece of metal that is riveted to the backing plate of the pads and will come in contact with the rotor when the pads are worn down to the minimum. It's there so you don't get metal to metal wear, i.e. backing plate on rotor. If that's not it maybe you have a little animal up in there.
Old Aug 19, 2001 | 11:32 PM
Wet Nudl's Avatar
New User
Default Re: Squeak sound (SMSP)
What's up David?? How you doing?
Old Aug 19, 2001 | 11:34 PM
Type Goch's Avatar
New User
dave, will that happen even though im not on the brakes?
Old Aug 20, 2001 | 06:41 AM
pcorad's Avatar
I've been chasing a squeak for months. I thought it was suspension/wheel related, but I've finally figured out it's coming from the exhaust system.
Old Aug 20, 2001 | 07:04 AM
Kengs's Avatar
Yes, if they are worn completely. It's an intermittent noise right?
Just had the rear pads in my wife's Accord replaced for the exact same reason.
Old Aug 20, 2001 | 09:17 AM
Blue Liquid's Avatar
New User
Sounds to me like the squealer tabs are showing through on your brake pads. You need to have them replaced. Take the car to an Acura dealer, have them measure the thickness of your pads, it sounds like you'll need new ones. The noise comes from the indicator tabs. It's a saftey measure designed into the pads to let you know they need to be replaced.
Old Aug 20, 2001 | 09:21 AM
Type Goch's Avatar
New User
Default Re: Squeak sound (Yellow R #01-0468)
will simply replacing the pads do the trick?
Old Aug 21, 2001 | 12:27 AM
Type Goch's Avatar
New User
well here's an update on the sound...its a repeated sound going along the rotation of the wheel. It makes the sound only while in motion and gone during braking....whats up?
[Modified by Type Goch, 3:34 PM 8/25/2001]
Old Aug 25, 2001 | 02:35 PM
Type Goch's Avatar
New User
TTT
Old Aug 25, 2001 | 10:33 PM
Type Goch's Avatar
New User
anyone?
Old Apr 29, 2003 | 12:03 PM
johnisenglish's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type Goch &raquo;</TD></TR><TR><TD CLASS="quote">well here's an update on the sound...its a repeated sound going along the rotation of the wheel. It makes the sound only while in motion and gone during braking....whats up?
[Modified by Type Goch, 3:34 PM 8/25/2001]</TD></TR></TABLE>
This is a serious back from the dead post, but ttt, because I'm having the same issue
Old Apr 29, 2003 | 08:16 PM
blktyper919's Avatar
Default Re: Squeak sound (johnisenglish)
i experienced the same, its the brake pads worn out
Old Apr 29, 2003 | 08:34 PM
Hondatec38's Avatar
Default Re: Squeak sound (blktyper919)
Could be a bum wheel bearing too. I think it's the pad's, but I just wanted to add that possibilty. I hope it's the pads. Replacing wheel bearings suck. And they pay crappy too for flat rate.
Old Apr 29, 2003 | 09:19 PM
Type Goch's Avatar
New User
Woah, I don't even remember posting this up. But...I think it was worn brake pads.
DjJohnnyStorm90
Honda Civic (2001 - 2005)
Dec 26, 2011 06:46 PM
kimota
Sep 26, 2005 01:23 PM
integranator
Dec 9, 2002 03:10 PM
cracker099
Sep 6, 2002 05:57 PM
