Oil Pressure Sensor Leak
Old Sep 8, 2003 | 03:08 PM
jaysonx's Avatar
Default Oil Pressure Sensor Leak
Hi Guys:
This is one of the LAST THINGS I have to take care of on my B20 until it is perfect. My oil pressure sensor is constantly leaking for some reason. I have removed it, applied new liquid gasket and put it back in (twice), but it still slowly oozes out oil. I cant tell if its leaking from the sensor (if this is even possible) or if its around the threads itself. All I know is the connector and little boot are constantly coated with oil, and it gets so bad that it pools under the filter and then drips on the header, then of course burns and smokes like a bitch.
Can I try and use something different to get a better seal? I am so frusturated with this that I almost want to get the hole plugged
Help is appriciated.
Old Sep 8, 2003 | 04:50 PM
inspyral's Avatar
Are you sure it's not leaking from somewhere above the sensor and dripping down? If you h ave a spare sensor around, I would try swapping that in. If you're using Hondabond, Permatex, or a similar sealant, it shouldn't be leaking from the threads, unless you don't give the sealant enough time to set up.
Old Sep 8, 2003 | 05:07 PM
jaysonx's Avatar
Default Re: (inspyral)
I'm positive its not above the sensor because I have verified the leak by watching it while I rev the engine.
I am just using some generic sylicone sealent that I got from Advance Auto. I let it set up for 24 hours (as per the directions) but it still didnt seem to fix it. Maybe I should try for something different.
I just checked and the sensor off my D15B7 seems to be the same. I will get some new sealant and plug that in tomorrow afternoon. (crosses fingers)
Old Sep 8, 2003 | 05:31 PM
Benny Hinn's Avatar
Default Re: (jaysonx)
teflon tape.
Old Sep 8, 2003 | 05:46 PM
jaysonx's Avatar
Default Re: (Benny Hinn)
I had thought about that, but I was afraid that some might break off and float through the oil system. So this is ok?
Old Sep 8, 2003 | 05:52 PM
quik1's Avatar
If you didn't use teflon in the first place that is the reason why it is leaking. When you put it on just make sure that the first thread doen't have any teflon tape on it and you will be fine. You can also use teflon paste.
Old Sep 8, 2003 | 06:06 PM
jaysonx's Avatar
Default Re: (quik1)
I've been using sylicone selant (per helms). I will try teflon tomorrow with my other sensor.
Old Sep 8, 2003 | 06:17 PM
quik1's Avatar
Sorry to ask a dumb question but you are putting the sealant on the treads right?
Old Sep 8, 2003 | 06:24 PM
jaysonx's Avatar
Default Re: (quik1)
LOL of course
Ive been putting it on the threads, torquing it in, letting it set up for 24 hours then cranking the engine.
Old Sep 8, 2003 | 08:21 PM
Stripped Honda's Avatar
99-0104
this is a very common thing to happen you just need a new oil pressure sending unit ... they are not expencive at all
i usually change 2-3 of them a week at the shop ....
07CRV
Honda CR-V & Element
Sep 30, 2016 04:07 AM
93CharcoalHatch
24
Jan 9, 2006 04:19 AM
93CharcoalHatch
Jan 6, 2006 09:42 AM
gsrra
Dec 25, 2005 06:50 PM
Canuk_SiR
Aug 1, 2002 12:16 PM
