P28 with B18B??
Old Sep 8, 2003 | 03:02 PM
jetpilot's Avatar
Default P28 with B18B??
i have a 92 si with a p28 ecu, i want to swap in a B18B1 with nonvtec head. What do I need to do? Chip the ecu? Can I run the stock program? and leave the vtec selenoid and pressure sensor wire unplugged? THANKS
Old Sep 8, 2003 | 03:18 PM
Katman's Avatar
Default Re: P28 with B18B?? (jetpilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetpilot &raquo;</TD></TR><TR><TD CLASS="quote">i have a 92 si with a p28 ecu, i want to swap in a B18B1 with nonvtec head. What do I need to do? Chip the ecu? Can I run the stock program? and leave the vtec selenoid and pressure sensor wire unplugged? THANKS</TD></TR></TABLE>
you can have the P28 reprogrammed with a non-vtec (LS) program and it will run on LS specs. No check light as long as everything is wired up correctly.
cyhm
Aug 5, 2014 05:54 PM
4cylinders-of-fury
Sep 14, 2007 07:43 AM
aberfoyle
Dec 13, 2004 12:37 PM
wm5holla
Jul 14, 2003 09:12 PM
integracivic94
May 15, 2003 02:24 PM
