Corbeau Seat harness, any thoughts?
Old Sep 8, 2003 | 10:59 AM
Bbasso's Avatar
Default Corbeau Seat harness, any thoughts?
I picked up a pair of these and would like to know what you think.
I did read that they are not for street/track use and only for autocross- but what would be so bad about using them for the street?
Old Sep 8, 2003 | 11:07 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Corbeau Seat harness, any thoughts? (Bbasso)
If you were injured in an accident it could possibly pose a problem with your insurance. They could reject the claim if you had personal injury and we wearing a seat belt that was no street legal. Just a thought....
Plus, they are a pain in the ***.
Old Sep 8, 2003 | 11:10 AM
bus stop's Avatar
why you want to use it for STREET driving.......you think the oem 3 point belt is not safe enough???
Old Sep 8, 2003 | 11:14 AM
Bbasso's Avatar
I think they are just fine and dandy for safety and for the Ins Co. but my fat *** slides around in the seat once in a while and I was hoping to keep it from moving.
Old Sep 8, 2003 | 11:15 AM
1GreyTeg's Avatar
Rob, the rule of thumb with harnesses for street and track requires at least the installation of a rollbar to protect you in the event of a rollover.
The danger or using a harness without the rollbar or cage would be when you'd be stuck in an upright position with no slack and no way to avoid any head or spine injury if/when the roof collapses.
I'm certain NASA and SCCA will not allow you to run at a track with a harness without at least the rollbar. At least thats what I've come to believe this season, and can understand fully.
Autocross is a different story. I can only speak for myself and I have personally experienced a rollover directly in front of me at an Autocross so the danger is there but, there is significantly more danger with rollovers on the track and street.
Get a rollbar before you get a harness.
Old Sep 8, 2003 | 11:23 AM
Bbasso's Avatar
Default Re: Corbeau Seat harness, any thoughts? (1GreyTeg)
Roll overs, I know the dangers and thats why I was asking about this particular harness. It really does not lock a person into an upright position and the stock seats will collapse if needed.
Just tossing some ideas/thoughts into the air.....
ill phil's Avatar
Then would Autopower street roll bars be legal in NASA and SCCA use?
Old Sep 8, 2003 | 11:30 AM
johnzm's Avatar
Default Re: Corbeau Seat harness, any thoughts? (ill phil)
yeah man rollovers are not an issue with this harness as it allows the body to slide down if there was any compression from up top..
Old Sep 8, 2003 | 12:02 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill phil &raquo;</TD></TR><TR><TD CLASS="quote">Then would Autopower street roll bars be legal in NASA and SCCA use?</TD></TR></TABLE>
Not that I want to make a stink, but what does roll bars have to do with my topic?
I'm not asking about harness and rollbars- just a harness.
Bbasso's Avatar
Default Re: Corbeau Seat harness, any thoughts? (johnzm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">yeah man rollovers are not an issue with this harness as it allows the body to slide down if there was any compression from up top..</TD></TR></TABLE>
Thats what I was thinking...
Old Sep 8, 2003 | 01:33 PM
ill phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
I'm not asking about harness and rollbars- just a harness.</TD></TR></TABLE>
Just wondering for the fact that they are always brought up when asked about harnesses and any type street use. And in this topic as well.
Old Sep 8, 2003 | 01:43 PM
IGGY's Avatar
Um, no. If you have 4 points and you can slide under them, then they will not protect you at all. In the event of an accident or sudden stop you may also find yourself under those belts.
If you want added saftey what I have done is first I installed an Autopower roll bar, and next I used Sparco 3" four points. Now that I have a Mugen bucket seat I will install a 5th point so I don't "slide down".
iheartktwenties
Dec 9, 2007 08:16 PM
chjkingme
15
Jul 2, 2005 04:35 AM
swift-speed
10
Mar 21, 2004 09:40 PM
95dc2
32
Jan 29, 2004 08:08 PM
xevanx
23
Mar 13, 2002 04:42 AM
