where do i get sub rings?
you can buy them from http://www.selectproducts.com, but they are super expensive....
The best way to make them, is with a jasper router jig (or homemade, but the jasper one is the best by far) and a router.
They come out perfect every time.
If you don't have the tools to do this, you can get them made by Mr. Marv over on elitecaraudio.com - do a search for him and you will get plenty of info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 »</TD></TR><TR><TD CLASS="quote">
I like my homemade jig. It only cost me 4 dollars and makes perfect cuts every time.
I would like a jasper if it would fit my router though. I think it is a little expensive at 40 dollars, but cnc machining is expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teen Heartthrob »</TD></TR><TR><TD CLASS="quote">tupac in oregon!!! westsiiiiide!!!!!</TD></TR></TABLE>
lol do you live in oregon? I do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg »</TD></TR><TR><TD CLASS="quote">
I would like a jasper if it would fit my router though. I think it is a little expensive at 40 dollars, but cnc machining is expensive.</TD></TR></TABLE>
I used to have a home-made jig, but I hated having to remeasure, then drill a new hole every time.
I thought the Jasper jig was expensive, until I used it for the first time. It's the most essential accessory (besides good bits) for a router. Now that I look back on it, I would have paid $80 for one. It's graduated in 1/16th" increments....can't beat that!!
True, but I did not buy a router that it would work with. The black and decker router that I have has a strange bolt pattern for the vacuum thing. So it will not work for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkvibe »</TD></TR><TR><TD CLASS="quote">Time for a retarded question. Whats a sub ring? A template to cut the hole in a box?</TD></TR></TABLE>
that or something they're using on a fiberglass box
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus »</TD></TR><TR><TD CLASS="quote">it's a wooden ring to screw the sub into; you put it where the hole for the sub is on a fiberglassed box.
Can also be used as a spacer for smaller speakers (especially in the shallow *** doors in Hondas).
chinoty
Welding / Fabrication
Jul 16, 2005 10:34 AM
