stubborn stains, waterspots.
Old Sep 8, 2003 | 06:26 AM
speedaccordinly's Avatar
Default stubborn stains, waterspots.
guys i got a black car and all over the roof theres waterspots and stubborn embedded stains that are into the paint which i cant get out, ive tried polishing compount, cleaner waxes. nothing... anyone have a solution ?
Old Sep 8, 2003 | 10:28 AM
AcCO12D95's Avatar
Default Re: stubborn stains, waterspots. (speedaccordinly)
You might want to try using a strong buffer machine.
Old Sep 8, 2003 | 01:10 PM
stickercuttingcom's Avatar
A buffer machine + no experience using a buffer = destroyed paint.
If you don't know how to properly use a buffer, burning the paint or ripping off the clearcoat is pretty easy to do.
Take it to a detailer.
Nate.
Old Sep 8, 2003 | 01:26 PM
94AccordCoupe's Avatar
Default Re: (stickercuttingcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stickercuttingcom &raquo;</TD></TR><TR><TD CLASS="quote">A buffer machine + no experience using a buffer = destroyed paint.
Try clay bar, that should take out a lot of the stains. As far as a buffer goes, you can get a buffer that won't destroy your paint, I think its called an "orbital" buffer, um or that could be the bad kind I forget. I know Meguire's makes a good one. Anways you should be able to get the same results by hand, just takes a little more work. If clay bar doesnt work try a stronger compound, I use 3M fine cut rubing compound alot. Just don't overuse it or you could take off the clear cloat
coat.
JamesV
Jun 5, 2006 08:10 PM
972drcordex
May 25, 2004 08:45 PM
xcom
Feb 29, 2004 03:08 PM
grandmasterflex
27
Jan 21, 2004 06:25 PM
deeweezy
Aug 17, 2003 07:19 AM
