need help with fuel
i have a 93 intega build gsr with a wabro pump for maybe one year already. well at idle i have it set a 45 psi and at about 6 grand on i just lose fuel pressure could that be caused by the pump or by the regulator because i am using a cheap *** reg ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c-93 »</TD></TR><TR><TD CLASS="quote"> i have a 93 intega build gsr with a wabro pump for maybe one year already. well at idle i have it set a 45 psi and at about 6 grand on i just lose fuel pressure could that be caused by the pump or by the regulator because i am using a cheap *** reg ...</TD></TR></TABLE>
how do you know you are loosing fuel pressure? is that at N, & reving it to 6,000rpms or with LOAD?.... do you have a cel on?
walbro are great..... but it is possible you have a defective one. I'd check the pump as a last resport.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c-93 »</TD></TR><TR><TD CLASS="quote">yes i have a fuel press gual inside and wright at 6000 press just drops to 40 down on. other people have told me to check my regulator and go from there </TD></TR></TABLE>
you have a gauge INSIDE your car or in your engine bay?
your are seeing this RIGHT when you are at 6000rpms... are you driving or just in neutral?
I have a fuel pressure guage on the regulator and on my pillar next to my air to fuel meter, i changed my fuel filter today and it seems to have helped out just barely drops but still thinking about changing out the regulator..
have you any bad things about the wabro pumps going bad or no
