What to do with the exhaust pipe rattling against heat shield?
I have a 94 Accord Coupe with the Tanabe Racing Spec. The problem I have is that the pipe is now rattling against the heat shield. I've looked and see now that the pipe is pretty much touching the shield. Does anybody know what I can do to give more room between the shield and pipe? Thanks in advance.
bend the heat shield back if there's room. i had a problem with my exhaust hitting the end of the shield toward the rear of the car after i got a little hung up on a manhole rim. it bent my midpipe a little so i had to make some "adjustments" to get the muffler back over and in doing so the pipe hit the shield. i just slid under the car when it was on the stands and bent it out of the way. and it's soft aluminum, i just used my hands.
r_kage
Aug 27, 2016 12:51 PM
