Anyone install 6x9 speakers in there R?
Old Sep 7, 2003 | 07:56 PM
ScaleExtric's Avatar
Default Anyone install 6x9 speakers in there R?
Well...as I mentioned before...about my stereo problems..I went out and bought a 300.00 dollar clarion cd unit for my integra. Sounds clear..however lacks the speaker quality which I knew I was gonna face. I know one of the big problems that the integra consist of..is that the speakers consist of only a size of 6 and half's.
Anyone of you guys run 6x9's in the back? or got them to work without cutting anything..and what kind of aftermath quality in sound did you get?
Im gonna put some new aftermarket speakers...but I think with the stock size speakers...Imma lack alot of bass and more treble..which is not what I want.
Thanks guys.
Old Sep 7, 2003 | 08:05 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Anyone install 6x9 speakers in there R? (ScaleExtric)
You won't fit 6x9's without major hacking.
Listen to some quality 6.5's to see if they have the sound you want, and if you can't find any two or three-way speakers that sound good, look into separates.
Or think about a small sub.
Old Sep 8, 2003 | 12:03 AM
00 FBP ItR's Avatar
Default Re: Anyone install 6x9 speakers in there R? (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">You won't fit 6x9's without major hacking.
Wrong!!! ... (don't take it offensively)
It mounts in perfectly fine.. w/ NO CUTTING.
You just need to remove the whole speaker pod. then it'll fit you just need a couple of self-tapping screws. then you'll be fine.
If you want me to take pics of mine i can.
Old Sep 8, 2003 | 05:48 AM
Splat's Avatar
Default Re: Anyone install 6x9 speakers in there R? (00 FBP ItR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote">If you want me to take pics of mine i can.</TD></TR></TABLE>
I don't mind being wrong
Let's see the pics
Old Sep 8, 2003 | 05:51 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote">You just need to remove the whole speaker pod. then it'll fit you just need a couple of self-tapping screws. then you'll be fine. </TD></TR></TABLE>
hrmm... sounds like my shopping just took at turn for the better... 6X9 = bumps in da trunk.
please do.
Old Sep 8, 2003 | 06:31 AM
AssPenny's Avatar
Default Re: Anyone install 6x9 speakers in there R? (Willard)
Just bump the 6" sub of furry
Old Sep 8, 2003 | 07:15 AM
Default Re: Anyone install 6x9 speakers in there R? (AssPenny)
Thanks guys for the input..however Im am trying to stay away from any type of sub. I have no back seats or trunk carpet..and plan to keep it that way. The radio isnt all that important to me...cause I rarely drive the car..however..wanted to see if I can get away with getting some nice mids and highs and bass as well.
Old Sep 8, 2003 | 07:42 AM
Jason's Avatar
I had a nice set of 6.5 components up front and 6.5's in the rear...I wouldn't get 6x9's, as a circular woofer is always better...
Mine was setup w/ their only duty being mids and highs, as I had a sub for the low frequencies, but they still sounded awesome...
stick w/ the 6.5's, but make sure they are a quality set. FWIW, mine were MB Quarts...
Old Sep 8, 2003 | 07:44 AM
Default Re: Anyone install 6x9 speakers in there R? (Jason)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason &raquo;</TD></TR><TR><TD CLASS="quote">I had a nice set of 6.5 components up front and 6.5's in the rear...I wouldn't get 6x9's, as a circular woofer is always better...
stick w/ the 6.5's, but make sure they are a quality set. FWIW, mine were MB Quarts...</TD></TR></TABLE>see..what i am trying to acomplish is staying away from the whole sub and amp.
I have a Nissan frontier with a superb sounding stereo system that has mids,high and bery nice bass.
I wanna get that kind of sound quality from the integra.
Old Sep 8, 2003 | 07:47 AM
Rob :190:'s Avatar
I have a set of 6.5 free air woofers mounted in the rear speaker location of my hype r, havent hooked them up yet, but they should do ok for me, as i'm not a bump nut
Old Sep 8, 2003 | 08:07 AM
Jason's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScaleExtric &raquo;</TD></TR><TR><TD CLASS="quote">see..what i am trying to acomplish is staying away from the whole sub and amp.</TD></TR></TABLE>
You don't NEED to have a sub to have decent sounding bass...but what I was trying to express is that if you get a good set of 6.5's, you can have enough bass...just don't expect to get it out of a $100 set of rears...my Quarts cost me over $300, and that was just for the rears...the components were almost $500...I wanted to go the route of a sub, b/c I already had the equipment from a previous install...
Rob...is there going to be enough air space behind the panel to do this? The area back there is somewhat cramped so I don't know how they'd perform...guess it can't hurt to try!
Old Sep 8, 2003 | 08:39 AM
Rob :190:'s Avatar
I had to dremel the stock speaker basket a bit, and make a spacer type thing to bring the speaker out a bit, other than that it fits fine. just need to get an amp now
Old Sep 8, 2003 | 08:46 AM
Default Re: Anyone install 6x9 speakers in there R? (Rob :190:)
Anyone know the difference between a component speaker and regular speakers?
Old Sep 8, 2003 | 09:06 AM
Splat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScaleExtric &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know the difference between a component speaker and regular speakers?</TD></TR></TABLE>
Component = separate speakers for highs and bass/midbass. Typically a small tweeter and a 5.25-6.5 driver along with a dedicated crossover.
Regular = multiple drivers (usually) combined into one "speaker."
Old Sep 8, 2003 | 09:09 AM
B_CRUZ!'s Avatar
... and the regular ones suck. I hate my 3 ways.. .
Old Sep 8, 2003 | 09:27 AM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">Just bump the 6" sub of furry
Believe it or not, that **** bumps.
Old Sep 8, 2003 | 10:21 AM
B_CRUZ!'s Avatar
Default (AssPenny)
is that a sealed or ported set up and whats the rms wattage of the amp you are using?
Old Sep 8, 2003 | 10:40 AM
STOLEN - ITR 98-0652's Avatar
You don't NEED to have a sub to have decent sounding bass...but what I was trying to express is that if you get a good set of 6.5's, you can have enough bass...just don't expect to get it out of a $100 set of rears...my Quarts cost me over $300, and that was just for the rears...the components were almost $500...</TD></TR></TABLE>
You spent $800 in speakers? For an ITR?
I can't hear the POS stock system. I think the esoteric speakers would be wasted in such an environment of ambient noise... err... "mechanical music".
Even the audiophiles will have to admit the sound quality difference gets less and less the more you spend (i.e. big difference between $100 and $200, moderate between $200 and $400, and infinitessimle between $400 and $800). It is a known principle of economics called "The Law of Diminishing Marginal Utility". There are so many "improvements" that could be made to an ITR to alter it as a listening environment before such speakers are cost effective... however all of those things fly in the face of that which makes it an ITR.
Old Sep 8, 2003 | 10:42 AM
AssPenny's Avatar
Default Re: (AssPenny) (B_Cruz)
The box is about .25 cu feet and has a 9 inch long x 1.5 inch dia. port. It is rated at about 120 watts and I think I'm pushing about 45 to it (It's a pos realistic amp rated at 75 watts, but i seriously dought it puts out more then 45 watts).
To me it is perfect. Its the size of a shoe box and it weights about 4lbs. It fills in the bass missing from the stock speakers. It is nothing like a 10 or even an 8 as it does not rattle your insides, but I really don't care for that anyways.
D made one too that is sealed and fits in his spear wheel
Old Sep 8, 2003 | 10:44 AM
B_CRUZ!'s Avatar
Default Re: (AssPenny) (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">The box is about .25 cu feet and has a 9 inch long x 1.5 inch dia. port. It is rated at about 120 watts and I think I'm pushing about 45 to it (It's a pos realistic amp rated at 75 watts, but i seriously dought it puts out more then 45 watts).
D made one too that is sealed and fits in his spear wheel </TD></TR></TABLE>sounds good. I have a few audio stuff left from my old cars.... I see a DIY little 6" sub in my future
Old Sep 8, 2003 | 10:50 AM
AssPenny's Avatar
Err... I made a mistake, its only 75 watts. But it still does the job.
Here is info on it: http://www.jlaudio.com/subwoofers/6w0.html
Old Sep 9, 2003 | 06:59 AM
Splat's Avatar
Where are the pics, y0?
Still curious to see the fitment
Old Sep 9, 2003 | 06:15 PM
00 FBP ItR's Avatar
Still curious to see the fitment </TD></TR></TABLE>
Lazy to pull off the panel...
i'll take off the grill and snap a pic though.. i got loads of school work to do
Old Sep 9, 2003 | 06:31 PM
Seedc2's Avatar
damn thats a pretty sweet little box you got there.
I never knew they made them that small!! im getting one now
Old Sep 9, 2003 | 07:15 PM
Jason's Avatar
Default Re: Anyone install 6x9 speakers in there R? (ITR 98-0652)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98-0652 &raquo;</TD></TR><TR><TD CLASS="quote">
No, I had the speakers previously, but they were worth every penny...If I'm going to do something, I'm going to do it right...and that means MB Quart speakers...
Regardless of the car, I've always been an audio freak, but less now in vehicles...I enjoy a nice system...
