second o2 sensor bung
Old Sep 7, 2003 | 07:49 PM
iGoneRacing_GSR's Avatar
Default second o2 sensor bung
Does anyone have experience in welding an o2 sensor bung? I just got a new greddy header, but it only has one bung. I also bought a new bung and i need advice on how to weld it on.
Old Sep 7, 2003 | 08:13 PM
Default Re: second o2 sensor bung (crx_b16a2)
ttt
Old Sep 7, 2003 | 09:11 PM
Rywire's Avatar
OK, get one more bung, you need 2. The one in the header cant be used, plug it up with a bolt or something. Put the 2 sensord in factory first gen locations. 1 in each pipe of the
"2" in the 4-2-1 header design. Ryan
Old Sep 7, 2003 | 11:40 PM
Default Re: second o2 sensor bung (droppedcrxsi)
for those who had to do this also, did you weld the bung on yourself? If so what kind of weld did you do? any advice?
Old Sep 7, 2003 | 11:55 PM
solman74's Avatar
I've not had the problem yet but most of the exhaust work I do in my shop is with my Mig welder. Your gonna use a 20-30mm line. the larger the number the more splatter your gonna get. I'd suggest 23mm steel line with flux. If you don't know how to weld you might want to have a shop do it real quick. Most shops to bang that out in no time and it shouldn't be any more than 10 bucks. To much more than that and they are taking you for a ride. You can go to Not home deport or lowes one of the other ones. I can't recall the name off the top of head but they carry odd sized pieces. I hope this helps
Old Sep 8, 2003 | 11:26 AM
Default Re: second o2 sensor bung (solman74)
thanx for the info solman75...
Old Sep 8, 2003 | 04:08 PM
headhunter's Avatar
or you can go buy this header - JDM Stainless Steel RS*R 421 b16 header , has the o2 bungs already in it from the factory. here is a pic of it on my car, crappy digi, sorry. best i could do. it shows the placement of the o2s. it this position, i can take the o2's off no problem. no need to pull manifold off. i think this header is rare, so i wouldn't go looking for it. seriously this header kicks ***. noticeable gains and very nice clearance, and got rid of all my rattles and noises from my b16 stock manifold.
thanks for the space.
Old Sep 8, 2003 | 04:55 PM
customx_'s Avatar
New User
isnt that rsr just the upper half?
Old Sep 8, 2003 | 04:59 PM
jaydm98's Avatar
Default Re: second o2 sensor bung (headhunter)
What car do you have the rs r header in crx or civic did you have to modify the crossmember? thanks.
Old Sep 8, 2003 | 11:21 PM
headhunter's Avatar
it is a full 421 header, 2 piece. it is on my crx. modification to the cross member was minimal. nothing major.
Old Sep 8, 2003 | 11:53 PM
skud_dusty's Avatar
Default Re: (headhunter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by headhunter &raquo;</TD></TR><TR><TD CLASS="quote">it is a full 421 header, 2 piece. it is on my crx. modification to the cross member was minimal. nothing major.</TD></TR></TABLE>
"Cleatus, get the hammer...this sum'bitch aint a movin"
Old Sep 9, 2003 | 03:19 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by headhunter &raquo;</TD></TR><TR><TD CLASS="quote">or you can go buy this header - JDM Stainless Steel RS*R 421 b16 header , has the o2 bungs already in it from the factory. here is a pic of it on my car, crappy digi, sorry. best i could do. it shows the placement of the o2s. it this position, i can take the o2's off no problem. no need to pull manifold off. i think this header is rare, so i wouldn't go looking for it. seriously this header kicks ***. noticeable gains and very nice clearance, and got rid of all my rattles and noises from my b16 stock manifold.
thanks for the space. </TD></TR></TABLE>
Thats very nice!!! Ryan
Old Sep 9, 2003 | 04:05 PM
headhunter's Avatar
thanks, it would've looked nicer if i had taken the time to clean it up a bit. any tips on what to use to shine up stainless steel, is there any way off reviving it back to its original color and shine.
lswantsvtec
Jul 22, 2007 08:06 PM
si0385.
Aug 24, 2006 04:48 AM
Rhythmsnewsn
Jun 15, 2006 08:10 PM
wwang924
12
Feb 19, 2006 09:21 PM
roydogg
Dec 2, 2003 09:27 AM
