Squeaky SSR Suspension
I have a SSR rear suspension set up. ( Lower Controll Arm, Tie bar, Sway bar). For anyone with this setup or other simliar setup, doyou know why there is a squeaky noise? I am thinking that maybe the bushing is new and it need to be broken in.
If you know or have any ideas of how to get ride of the squeaky noise, please let me know. Thank you for all your help and advice, any ideas will help at this pooint.
The best thing to do first is to find out if it's coming from the right or left side. Helps narrow down where you need to look/check.
Also, did you put some grease in the bushings before installing those?
When you put all the new suspension pieces on did you greese up all the bolts and holes that would be rubbing or moving? Maybe a dab of some kind of synthetic greese on each of the pieces would quite things down a little more or solve the problem entirely.
I agree with the Lube.. ya gotta do that on the right spots to prevent the squeaking.
We have installed quite a few of these kits.. and thats all you need to get the squeak here and there to go away.
PittsburghNBP
Apr 12, 2011 11:15 AM
