Body kit
if you want it to fit then should get it done from someone that knows what they are doing but if you want shitty fit then do it yourself and it might be ok but most likely it wont fit right
good luck
good luck
urethane usually fits good as is thats what ive got and i put mine on no problem. however, i have heard that fiberglass generally does not fit as good and requires more work, but in my experience if you can use a drill- you can install a urethane kit
