Cable to Hydrolic tranny swap.
Old Sep 7, 2003 | 04:50 PM
soundman's Avatar
Default Cable to Hydrolic tranny swap.
I am wanting to switch my D16A6 transmission to a Y8 transmission. How hard is it to switch to the hydrolic clutch, and do I need a different transmission mount for the hydrolic tranny? I am looking for a stronger D series tranny.
Old Sep 8, 2003 | 10:04 AM
soundman's Avatar
Anyone good with transmissions?
Old Sep 8, 2003 | 10:11 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Cable to Hydrolic tranny swap. (soundman)
There is no mount kit out for swapping in a hydro D-series tranny at this time. If you decided to put one in anyway, you would need to make custom mounts and also figure out how you wanted to deal with the hydrolic system. You could make some sort of adaptor and loose the hydro sysem completely or you could route tubing, fit the hydro clutch pedal assembly under your dash, and make it a tryue hydro system.
IMO - both of those routes are more trouble than they are worth. The A6 tranny should be strong enough. The weakness in the D-series trannies is the diff. Go get a nice Quaife LSD and you are set... maybe replace some synchro set while you are in there. A stock 92~2000 tranny has the same issues with the diff.
Old Sep 8, 2003 | 10:28 AM
soundman's Avatar
Default Re: Cable to Hydrolic tranny swap. (4drEF)
OK thanks for your help you answered my ?
Old Sep 8, 2003 | 11:29 AM
boosh's Avatar
HASport makes a mount kit for a cable to hydro, but i believe its only for the B series.
KodSol
Transmission & Drivetrain
Dec 19, 2011 10:13 AM
kim_2_da_chee
May 13, 2009 07:57 PM
E9CiViC1F
Jan 13, 2009 07:00 PM
Walterronny
May 27, 2006 04:12 PM
