fs: b16 head, rc injectors, sir (jdm) gauge cluster, lots more parts inside (midwest)
Old Sep 7, 2003 | 01:27 PM
b16powwer's Avatar
Default fs: b16 head, rc injectors, sir (jdm) gauge cluster, lots more parts inside (midwest)
email me if you need more info on any parts you see here.
buyer pays shipping, i am in chicago il. money order only if shipped out, or cash if picked up, email at faraj77@aol.com
b16a1 head, ported and polished w/skunk2 valve springs and ti. retainers. itr intake and exhuast valves. i spent over $800. in the head alone w/all the work. head is complete w/ever bolt and nut. asking $1000.
sir (jdm) gauge cluster for 90-91 civic/crx, comes complete w/elec. vss. and 90-93 integra speed sender and instuctions. asking $200. for all.
rc 310cc injectors (obd-0) $215.
itr red vavle cover $90.
itr intake manifold for b16/b18c5 $200.
b18b rods w/b18c1 pistons $75.
b16a1 valves, valve springs, retainers, (all 48 pcs.) $50.
gtec pro, still in the box. $200. firm
obd-1 injectors from a 95 gsr (got 2 sets) $50. for a set
b16a1 and b16a2 throttle bodys w/no tps or maps sensors asking $30. for each
apr head studs for a 1.8L (gsr or ls) complete set of 10 studs w/bolts $100.
91 crx si gauge cluster $25.
88-91 motor mount for doing a swap in a civic/crx, driver side mount only, asking $20.
aem pullies in red w/2 new belts (still new) $50.
b16a1 cams and cam gears, 5-speed, (i have 2 sets) $50. for a set
b16a1 stock fuel rail $15.
b16a1 stock fuel regulater $15.
99 stock gsr flywheel $50.
91 crx si stock rotors and pads (all 4 rotors in great cond) $50.
91 crx si stock fuel pump $30.
91crx si stock header $25.
91 crx si brake lines $50.
91 crx si stock suspention (springs and sturts) all 4 corners $75.
91 crx si stock steering wheel $20.
91 crx si used raditor $20.
optima battery in red $40.
Old Sep 15, 2003 | 10:29 AM
turbod16y8's Avatar
Default Re: fs: b16 head, rc injectors, sir (b16powwer)
bump check PM
Old Sep 17, 2003 | 03:06 PM
stevel's Avatar
Default Re: fs: b16 head, rc injectors, sir (turbod16y8)
who did the port/polish on the b16 head?
check your pm
s
Modified by stevel at 6:30 PM 9/18/2003
you449
Dec 9, 2013 10:43 AM
mikey mike
Aug 6, 2010 02:34 AM
noremorseracing
Apr 8, 2010 04:42 PM
cousin_ed
Apr 13, 2009 09:53 AM
