car class after cam gears?
Old Aug 19, 2001 | 11:45 AM
617arg's Avatar
Default car class after cam gears?
can anyone tell me what class i will be in once i add cam gears to my car. right now i have a CAI, header, and lightweight 15" wheels, and am currently in CSP. are cam gears considered internal modifications? if so what class would i be bumped to? thanks.
argiris
Old Aug 19, 2001 | 04:00 PM
travis's Avatar
Default Re: car class after cam gears? (argiris)
From the SP rules:
Any accessory pulleys and belts of the same type (e.g., V-belt, serpentine) as standard may be used. This allowance applies to accessory pulleys only (e.g., alternator, water pump, power steering pump, and crankshaft drive pulleys). It does not allow replacement, modification, or substitution of pulleys, cogs, gears, or belts which are part of cam, layshaft, or ignition drive or timing systems, etc. Supercharged cars are excluded from this allowance. This does not permit replacement of integral pulley-dampener/balancer assemblies.
I would think you would be bumped to SM. However, people on your local level might not complain if you declare everything.
f22abuilder
Feb 16, 2006 06:10 AM
pearlws
Honda S2000
Feb 19, 2004 03:41 PM
[HrZn]4life
Nov 3, 2003 04:45 PM
b18c-93
Apr 4, 2002 05:10 PM
