Radiator Help!!!
Old Sep 6, 2003 | 11:40 PM
UnrealSpeed's Avatar
Default Radiator Help!!!
UPDATE I got the radiator from Autozone for $99.99, its the Dual row for a DelSol VTEC. I got it installed a few hours ago, it took me 15min to remove the old one and put in the new one. All went smothly. Until I noticed the temp was still going up and the fan wasnt kicking in. I checked the fuce and thermostat and all was good. So I was stumped for a while, until I cheked the fan, which was fine. Then I followed the line back to where it plugs into the engine block and sure enough the damn plug end was busted to even if u pluged it in, the damn thing would just pop back off. So i did a quick fix until I could find a replacement off my friends wrecked EG Si. So all went well! And now I got a bigger rad and the temps stay below what they used to.
I was crusing the local downtown strip tonight and stoped to talk to a buddy of mine so I left my car running for about 5 min as I headed back to it, I noticed steam was rising from under the hood, so I ran in and right as I turned it off the radiator blew, Now here is the thing. I have never had problems with the car overheadting or anything, and I live in 120+ temps during the day and 88-92 during the night. I know the rad is gone cuz its got a 7-8' crack across the top plastic section right below the cap. If I replace it, what else should i look for that could have caused the blown rad. I also read about the DelSol VTEC rad's which are double core or something like that. What do you guys think would be the best way to go? Stock OEM or Aftermarket? Any places you guys know of that have them? Brands? Any suggestion are greatly appreciated
93 Honda Civic Si
Stock motor
Modified by UnrealSpeed at 9:18 AM 9/8/2003
Old Sep 6, 2003 | 11:58 PM
FF-sean's Avatar
Default Re: Radiator Help!!! (UnrealSpeed)
OEM delsol is really good
check all your hoses for (clogged)(holes)
thermostat..
water pump...
make sure your fan is working
Old Sep 7, 2003 | 12:04 AM
Default Re: Radiator Help!!! (ReaL JDM Eg6)
Do you know if the DelSol dual core OEM replacement can be picked up at, say a local, PepBoys or Kragens ect.....?
Old Sep 7, 2003 | 12:11 AM
blkgsr03's Avatar
my friend has a used radiator for sale i believe. PM for more info
Old Sep 7, 2003 | 12:16 AM
D16Z6racing's Avatar
Default Re: Radiator Help!!! (CiViC KiD)
94-01 Integra radiator.
you can find used ones with fans and hoses for $75-$150. then from $20-$50 for install, cause it requires your mount to be cut/moved/welded.
Old Sep 7, 2003 | 12:24 AM
Default Re: Radiator Help!!! (D16Z6racing)
Kinda looking to get that DelSol dual core rad, but where can I get it besides the internet?
Old Sep 7, 2003 | 12:40 AM
FF-sean's Avatar
go to your local honda junkyard you should find one....
theres a lot here in San Fernando Valley but your way too far to come down
Old Sep 7, 2003 | 12:42 AM
Kragen online has them and so does Autozone, do u think those are ok? Their the dual core for the Del Sol VTEC models. They cost $99 at both places. Any other places that might carry them?
Old Sep 7, 2003 | 03:04 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
hey ray i have an old radiator that has a small *** crack smaller than a tic tac...you can have it if you want..you might be able to get it fixed for cheaper than a new one...come check it out the hole is very very small
Old Sep 7, 2003 | 10:15 AM
Default Re: Radiator Help!!! (ciRcuitSi y0!)
sweet! I'll hit u up later one. Any other places where they might carry these?
Old Sep 7, 2003 | 10:23 AM
BLK JDM's Avatar
Check to see if your fan motor is blown or the fan fuse. I had almost the same problem but it was caused by the fan not coming on. Check the fuse under the hood by the battery or check the fan motor itself. Then check the hoses and the thermostat. Most people keep overlooking the fan until it's too late.
Old Sep 7, 2003 | 10:24 AM
JV's Avatar
JV
Who?
Radiators.com. $144.74 shipped to my door.
A little more than say Autozone, but not too much. Shipped quick. Fit like a glove and you can reuse your existing radiator cap...
Old Sep 7, 2003 | 02:58 PM
Default Re: Radiator Help!!! (JV)
I got one from Autozone today for $99.99 its the Del Sol VTEC one, its about twice the thickness of the stock one. Have'nt gotten around to installing it but hope all goes well.
Old Sep 7, 2003 | 03:00 PM
FF-sean's Avatar
Old Sep 8, 2003 | 12:19 AM
yes
chief8000
Jan 2, 2017 05:21 AM
98_civic_DX
Mar 28, 2007 04:59 PM
TC21
May 9, 2006 11:19 AM
envious1320
Mar 9, 2003 04:50 PM
