Volk Racing?? 4th gen size?
I'm looking into getting a set of 16in. V.R. TE-37's for my 4th gen S. Can anybody tell me what the offset would be? Also, is there a company that makes a short shift kit that also lowers the stick height? Thanks.
New User
From: Craigavon, Co. Armagh, Northern Ireland, Northern Ireland
The Prelude's offset was 55mm on 16x6.5 with 205mm rubber factory Spec for the 2.2 VTEC, the offset was the same across Si and VTEC Preludes. I wrote a small program that calcs all that stuff for you if you would like it? Try and get an offset of at least 40mm if you can - 45 to 48mm is the best.
Brian
Brian
