Why do I keep spinning rod bearings.....
When are you spinning the bearings? At the drag strip, road course or just street racing? If it's on a road course I might have the answer. Possible oil starvation. Just my 2 cents from a guy who has spun 3 as well.
you could also try checking your rods for an out of round condition, you can also use a memmory oil pressure guage, and monitor the oil pressure at high rpms to see if there is a drop or case of oil starvation, if you arent using synthetic in the motors already... (Group IV PAO) then it wouldn't be a bad time to start.
RS likes to set bearing clearances on the big side (around 2 thou) so it can't be from too tight of bearings. Lack of Oiling or Detonation is my guess...
Suprdave
Suprdave
you may want to go with a gsr block sleeved. But thatsalot more money and work other than staying with your setup. But the gsr blocks oil squirter help reduce cylinder temps, reducing detonation.
