car wont turn off
Old Sep 6, 2003 | 05:03 PM
Whitehatch18's Avatar
Default car wont turn off
Today coming home.. when i was going to turn off my car it didnt wanna turn off...the motor kept on running..i checked my ignition and everything look fine..everything else turns off but my cluster stays on has if the ignition was open..please if anyone knows about his situation pls w/b
Old Sep 6, 2003 | 05:24 PM
Relix H22a1's Avatar
Default Re: car wont turn off (Whitehatch18)
So your engine stay running after you turn the key to the off position? Or does your cluster just stay on?
Old Sep 6, 2003 | 08:45 PM
Angry Joe's Avatar
'dieseling' can occur if there is excessive carbon buildup in the combustion chanber, the engine will keep running after the ignition is cut (like a diesel). You might try throwing some injector cleaner in the engine to clean things out, or pull the head if you feel so inclined
Old Sep 6, 2003 | 09:11 PM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: car wont turn off (Angry Joe)
If you have a build up of carbon in your engine you should go out and get some "Sea Foam" I've only seen it at Napa stores but it works wonders on dirty engines!
Old Sep 7, 2003 | 11:18 AM
Stripped Honda's Avatar
99-0104
Default Re: car wont turn off (92 civic VX B18c)
possible bad ignition pigtale/switch
Old Sep 8, 2003 | 09:43 AM
redlinegsr's Avatar
Default Re: car wont turn off (Stripped Honda)
whats with the beer poll???
jdm_ek_noob
Jun 26, 2013 02:14 PM
klomast3r
Oct 5, 2006 01:26 PM
sgrahame21
Aug 31, 2006 08:31 PM
crx_88_si
Jan 18, 2006 04:48 AM
