86 accord with check light Pgm-fi
Old Sep 6, 2003 | 11:28 AM
hotmachines2000's Avatar
Default 86 accord with check light Pgm-fi
car is hard to start the Pgm-fi light is on fuel pump is working, filter is good.what might be the problem. once it starts runs ok if Pgm-fi light goes away runs like crap
Old Sep 7, 2003 | 11:57 AM
can u help with the problem
Old Sep 7, 2003 | 04:56 PM
Chiovnidca's Avatar
Default Re: 86 accord with check light Pgm-fi (hotmachines2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotmachines2000 &raquo;</TD></TR><TR><TD CLASS="quote">car is hard to start the Pgm-fi light is on fuel pump is working, filter is good.what might be the problem. once it starts runs ok if Pgm-fi light goes away runs like crap </TD></TR></TABLE>
What code does it have stored?
Old Sep 7, 2003 | 05:04 PM
88LXi68's Avatar
First,
turn the key to 1 and pull the driver side seat all the way forward. The ECU is under the driver seat and there is a little window in the back of it. The light in the window will flash and this will tell you what code you have.
Your problem could be a main relay, but without the code it is hard to tell.
Also, check out http://www.3geez.com it is an all 86-89 accord messageboard and can help ypu out with these problems faster than this site.
03EXL
13
Feb 21, 2014 09:10 PM
Spartoons
Jul 9, 2007 05:44 PM
MurdersV8s
Nov 13, 2006 03:26 PM
phill
Sep 2, 2004 07:19 AM
eL
Oct 25, 2003 05:25 AM
