News for ARC air box owners!
Old Sep 5, 2003 | 09:07 PM
Extreme's Avatar
Default News for ARC air box owners!
After extensive search, I have found inexpensive replacement for my ARC air box!
It turns out that the 200mm x 237mm filter used in the ARC air box is from JDM
Mazda FDs!
US FDs use a different filter, HOWEVER, the filter for the MPV is EXACT match!
Same filter is also used on some early 929s and B2600s. That means plenty of
choices for cheap filters: Purolator, Fram, etc. and of course, K&N, pn# 33-2117.
More pics here: http://www.n1-spec.com/gallery/arc/index.html
Modified by Extreme at 3:22 PM 9/6/2003
Old Sep 5, 2003 | 09:12 PM
sethm's Avatar
Default Re: News for ARC air box owners! (Extreme)
good find
Old Sep 5, 2003 | 09:15 PM
Pat McGroin's Avatar
Default Re: News for ARC air box owners! (sethm)
Where did you guys get the ARC airboxes?
Old Sep 5, 2003 | 11:14 PM
Red CiViC Hatch's Avatar
Default Re: News for ARC air box owners! (Pat McGroin)
take ur stock box off put it into the end of the tube upside down filter facing up.........did it on my 92 vx like 3 years ago when it was stock .......ghetto box
Old Sep 6, 2003 | 03:19 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
a few years ago, i did the same. i went through the k&n custom catalog, and found a filter that fit with only minor trimming. how thick is the foam (around the sealing edge) compared to the ARC filter? i had to shim mine, as the sealing edge was about half as thick as the ARC filter. i must try the mazda mpv one though. good job.
* i'll find more pics in a bit
Old Sep 6, 2003 | 06:20 AM
Extreme's Avatar
Default Re: News for ARC air box owners! (rodney)
Fram & Purolator fits perfectly, but the K&N is a little loose.
It's probably okay, but I may add a 1/8 thick foam strip inside the top cover.
Old Sep 6, 2003 | 06:49 AM
supadupamikey's Avatar
doesnt look very efficient... just my 2 cents
Old Sep 6, 2003 | 07:08 AM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: News for ARC air box owners! (supadupamikey)
anyone have dyno numbers for that or is more JDM bling ??
Old Sep 6, 2003 | 07:35 AM
Default Re: News for ARC air box owners! (spock_rocker)
bling maybe????? i did it for sound effects cause i got bored one day
Old Sep 6, 2003 | 10:00 AM
rodrez.'s Avatar
Always wondered about the ARC airbox. The air flow is supposed to be coming from the top of the unit right? I'm not sure how it's beneficial. Is it just supposed to be keeping the filter away from the heat of the engine? I'm not flaming at all, I'm just curious as to how it benefits performance.
Old Sep 6, 2003 | 10:22 AM
opi's Avatar
opi
good info, for sharing it
Old Sep 6, 2003 | 06:04 PM
Extreme's Avatar
Default Re: News for ARC air box owners! (rodrez)
The box draws cold air from between the hood and core support. It has a
funnel inside the box to enhance air flow. Its connected to a second chamber
via a 3". Inside the 2nd chamber is another funnel to enchance air flow. And its
stepped down to 2.5" outlet to the throttle body (I believe AEM's recently release
cold air V2 and others just started doing the same step down.) The overall
design seems to smooth out and slow down the air flow, thereby reducing turbulance.
Or simply, improving quality over quantity of air being fed to the motor.
This is an intake design to enchance the midrange performance of the torqueless
B16. One of the side benefit is the box is quiet, almost stock like compare to all
the other intakes (This is using both the box and the chamber. I have not tried
either alone, so may be other owners can elaborate.)
Modified by Extreme at 3:26 PM 9/7/2003
Modified by Extreme at 3:27 PM 9/7/2003
Old Sep 6, 2003 | 07:02 PM
rodrez.'s Avatar
I see, so it sort of sits at an angle, to pull in air, and smooth it out, nice.
Old Sep 6, 2003 | 09:06 PM
TheTruth709's Avatar
i want that air box, where can i get one?
Old Sep 6, 2003 | 11:19 PM
T4eg's Avatar
Default Re: News for ARC air box owners! (opi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opi &raquo;</TD></TR><TR><TD CLASS="quote">good info, for sharing it </TD></TR></TABLE>
Old Sep 8, 2003 | 04:04 AM
Kengs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez &raquo;</TD></TR><TR><TD CLASS="quote">Always wondered about the ARC airbox. The air flow is supposed to be coming from the top of the unit right? I'm not sure how it's beneficial. Is it just supposed to be keeping the filter away from the heat of the engine? I'm not flaming at all, I'm just curious as to how it benefits performance. </TD></TR></TABLE>
Rodney's ARC box (the EK version) has DUAL inlets, i.e., there is a second filter on the bottom side. I think he dynoed around 193hp with his B18C5, so the ARC does OK for power
Throttle response is to die for
Old Sep 8, 2003 | 07:30 AM
Dr. EKology's Avatar
Default Re: News for ARC air box owners! (kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">
Not saying you are wrong or anything, but I remember a thread a while back when someone did a few dyno runs with the ARC and it turned out that the ARC actually lost power! I'll search for the thread, hopefully I can find it....
EDIT: Found it! https://honda-tech.com/zerothread?id=314104
Old Sep 8, 2003 | 09:45 AM
Kengs's Avatar
Default Re: News for ARC air box owners! (EVIL_EKology)
yup, but that thread was referring to the skinny DC2 version ARC box, not the big *** EK box that Rodney and I have
Old Sep 8, 2003 | 09:49 AM
.saint's Avatar
damnit i just bought a new arc filter for my box :\..
heat wrap the ARC box (yeah looks stupid) but keeps the box colder better on the dyno..
Old Sep 8, 2003 | 09:59 AM
rodrez.'s Avatar
So there's actually a panel filter on the top and the bottom? I thought it was only on the top. Is this the same design for all models, or only the bigger EK version?
Old Sep 8, 2003 | 10:11 AM
B2FiNiTY's Avatar
Awesome find! people always have problems finding filters.
Old Sep 8, 2003 | 10:49 AM
Kengs's Avatar
So there's actually a panel filter on the top and the bottom? I thought it was only on the top. Is this the same design for all models, or only the bigger EK version?</TD></TR></TABLE>
The EG box only has one inlet; the DC2 and EK versions both have 2 inlets, and the EK box is actually quite a bit bigger than the DC2 version.
Boopaa
May 18, 2018 04:57 AM
conejo77
Honda CR-V & Element
Oct 12, 2014 12:28 PM
odiumred
Jun 22, 2007 11:27 AM
rev limiter
13
May 1, 2005 11:53 PM
dip-set
May 15, 2003 03:48 PM
