skunk2 intake manifold installation question.
Old Sep 5, 2003 | 06:25 PM
sung's Avatar
Default skunk2 intake manifold installation question.
im in the middle of putting a skunk2 intake manifold onto my LS motor. i've gotten it to the point where the stock manifold is off and switching the sensors over. the problem i have is the sensor on top of the stock intake manifold has no place to plug in on the skunk2 intake manifold... can somebody point me in the right direction?
Old Sep 5, 2003 | 07:40 PM
Westrock2000's Avatar
Default Re: skunk2 intake manifold installation question. (sung)
I think I've heard poeple just remote locating it, like some of the older Honda's. Thats the MAP sensor right? Although that kinda sucks for us cause those things don't have a nipple on them attach a hose to.
Hope that doesn't discourage you....hopefully someone will be able to better help you.
Old Sep 5, 2003 | 08:19 PM
b19coupe's Avatar
That thing on top of the IM is the EVAP purge control solenoid. It needs direct manifold vacuum to operate. I am getting the Skunk2 IM soon (I just need to pick it up), so I can better tell you how to hook it up when I have the Skunk piece in my hands. Do the instructions give any hint as to what needs to be done?
Old Sep 28, 2007 | 06:47 PM
tofu__'s Avatar
bump, i've been searching and still haven't found an answer for this
Any help would be great
Old Sep 28, 2007 | 07:01 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: skunk2 intake manifold installation question. (tofumonzter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofumonzter &raquo;</TD></TR><TR><TD CLASS="quote">bump, i've been searching and still haven't found an answer for this
Any help would be great </TD></TR></TABLE>
Search here as well:
http://www.skunk2.com/cgi-bin/kb.cgi
Old Sep 28, 2007 | 08:20 PM
SoTexDC2's Avatar
Default IM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">That thing on top of the IM is the EVAP purge control solenoid. It needs direct manifold vacuum to operate. </TD></TR></TABLE>
Correct.
Not sure about the Skunk 2, but on the Blox IM there is no vac. source for the Evap Purge Control Solenoid. You can easily mount it on the firewall, or just leave it off. I never had a CEL because of the Evap system.
Heres a few links:
http://www.ff-squad.com/tech/howto/sk2manifold/
https://honda-tech.com/zerothread?id=1141806
Good Luck!
Old Sep 28, 2007 | 08:21 PM
SoTexDC2's Avatar
Didn't realize the thread was 4 years old!
Check the links above, they should help you out.
95_red_dc
May 21, 2006 02:52 PM
i v o u s
Jan 27, 2005 03:31 PM
b20vtecv8killer
Oct 22, 2004 05:40 AM
sung
Sep 5, 2003 11:28 PM
