JDM ITR non-SRS Steering wheel in EF: HOW????
dude just rig those squares... use a square to figure out if they are level with each other... then figure out the measurement and use something to cut it... prob a dremmel will work.. should have working steering wheel with itr soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant »</TD></TR><TR><TD CLASS="quote"> I need a steering wheel to drive my car.
Just hit the junkyard and get a crapper for 10 bucks.. then you will be able to drive your car while you figure out how to get the ITR one working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant »</TD></TR><TR><TD CLASS="quote">Okay I got the wheel on finally, but I had to remove my signel thing that makes it so when you turn the wheel your signal turns off. By doing this I got it so that I could put the wheel down farther on the shaft and then acually bolt it on. So its on and the horn works, but to me it seems kinda half ***.
Update: just got an email back from a shop and they said that it looks as if my hub has been modified and thats why its not working. They also say they carry the right hub for me. I hope this is so and solves my problem that im having.</TD></TR></TABLE>
any updates? Did you order that new hub then? Oh, and definitely post some pics up for us. I want to see it in your car!
MeanstreakCivic
16
Aug 21, 2005 10:00 PM
