brake light
Old Sep 5, 2003 | 01:48 PM
Jeff99Base's Avatar
Default brake light
I have a weird brake light question. The light on the dash has started to come on even when the parking brake is off, which on most hondas indicates you are low on fluid, I am not.
The weird thing is, the light only comes on when its cold outside. It was about 50 out this AM and it came on, once the car reached normal temp the light went out. When I started the car to come home today it did not come on at all.
I was just wondering if any of you had ever seen the temp affect the brake system
Thanks,
-Jeff
Old Sep 5, 2003 | 01:58 PM
madcatz's Avatar
Default Re: brake light (Jeff99Base)
I had that all the time...never found out what it was though...I wrecked my car b4 I could get up in there and see what I needed to do.
Catz
TraKtioN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff99Base &raquo;</TD></TR><TR><TD CLASS="quote">I have a weird brake light question. The light on the dash has started to come on even when the parking brake is off, which on most hondas indicates you are low on fluid, I am not.
Thanks,
-Jeff</TD></TR></TABLE>
I would check your parking brake sensor.
Old Sep 5, 2003 | 02:34 PM
Jeff99Base's Avatar
Default Re: brake light (TraKtioN)
Which would be located where?
Old Sep 5, 2003 | 02:40 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff99Base &raquo;</TD></TR><TR><TD CLASS="quote">Which would be located where?</TD></TR></TABLE>
in your helms manual
Old Sep 5, 2003 | 02:48 PM
Jeff99Base's Avatar
Default Re: brake light (shakes)
Well I guess its an excuse to finally order the helms, I just got the car two months ago and have been putting it off.
Old Sep 5, 2003 | 08:19 PM
TraKtioN's Avatar
I'll give you a hint.....its near the parking brake.
Heh I'm such an ***.
Old Sep 6, 2003 | 07:09 AM
Jeff99Base's Avatar
Man that is so sweet of you. Thanks for the help.
BukThout
Apr 10, 2007 07:44 PM
JDMEJONE
Jul 14, 2006 08:32 PM
DSMRacing
Mar 29, 2006 10:37 AM
mashoutposse
Sep 5, 2005 01:05 PM
Gsrteggrl
Jul 2, 2005 10:06 AM
