Can I hook it up this way???
Old Sep 5, 2003 | 01:34 PM
96 Ls lnTeG's Avatar
Default Can I hook it up this way???
Well I just Recently out an new deck an eq (both kenwood it that matters) well my little brother just hooked me up with a pioneer 400watt 4 channel from his werk an i already have a infinity bassklink from my old car I like it cause of the size... well i will be relocating my battery to the trunk for cosmetic purposes ( i think it cool if any one want to know)
original plan was to buy 2 amp kits.. one 4 channel and one sub amp kit.... well
New Plan (maybe) I was told that I could do it with one kit (4 gauge) a distribtion block and a prolly another power wire an 3 sets of rca's (for my amp an basslink )
Well something close to that... Hopefully some can understand an correct me if i am wrong thanks peace
Old Sep 5, 2003 | 02:28 PM
t0p_sh0tta's Avatar
Default Re: Can I hook it up this way??? (96 Ls lnTeG)
Yes, you can use one amp kit with a distribution block.
Old Sep 5, 2003 | 05:39 PM
tegmech's Avatar
don't forget the capacitor!!!!
Old Sep 5, 2003 | 07:45 PM
t0p_sh0tta's Avatar
Default Re: (tegmech)
To hell with a capacitor.
Old Sep 6, 2003 | 06:35 AM
KingOcellular's Avatar
Just get one amp kit of proper guage wiring. 2 wiring kits is a waste. Also ground both amps to the same location to avoid a potential ground difference (possible noise in system).
Old Sep 6, 2003 | 07:34 AM
So do you guys think a 4 gauge kit is enough, and also does it matter what kind of Rca's that i get??? thanks
Old Sep 6, 2003 | 08:04 PM
pickup1's Avatar
Default Re: (96 Ls lnTeG)
4 gauge is plenty,but buy good rca's.get name brand and not the "bottom feeder cheepies".
Old Sep 8, 2003 | 09:56 AM
Default Re: (pickup1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pickup1 &raquo;</TD></TR><TR><TD CLASS="quote">4 gauge is plenty,but buy good rca's.get name brand and not the "bottom feeder cheepies".</TD></TR></TABLE>
So is 4 Guage to much??? should i go with 8???
Old Sep 9, 2003 | 03:22 PM
VTECorona's Avatar
better off with 4 guage, this way you can run X amps off of the same power wire and just divide it at the distribution block.
Old Sep 9, 2003 | 03:24 PM
PetroGuyX's Avatar
Default Re: (VTECorona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">better off with 4 guage, this way you can run X amps off of the same power wire and just divide it at the distribution block.</TD></TR></TABLE>
very true, better safe than sorry, i'm running 2 under-200 watt amps and i used 4 guage and a distribution block, but i had a 1600 watt in before
Old Sep 10, 2003 | 06:12 AM
pnthr30's Avatar
Default Re: (PetroGuyX)
Right now I have one kit (4 gauge) running two amps (Rockford Fosgate 250a2 and a Rockford Fosgate 400a4) and I have no problems with it.
Old Sep 10, 2003 | 09:54 AM
mstewar's Avatar
recommendations on distribution blocks?
Old Sep 10, 2003 | 02:45 PM
VTECorona's Avatar
Default Re: (mstewar)
Brand doesnt matter really, but if you're a brand ***** go with pheonix gold (if they're still around) But just make sure it accepts atleast 4 guage and has outputs for atleast 10-12 guage
deeboi
Audio / Security / Video
Dec 23, 2012 04:04 PM
E46Kid
Dec 27, 2006 02:16 PM
cilvia
15
Aug 29, 2005 11:18 PM
crystalblue99lude
Jun 21, 2005 04:57 AM
acidvoodoo
Aug 22, 2003 08:36 PM
