lsd or no lsd
as of now, i need an h22 tranny. i found one i think i am gong to buy, but it does not have an lsd. i also found a type s lsd for 400 bucks. do u think it is worth it to also buy the lsd unit. the h22 is going in a 92 cx if it matters
If you're on a budget what about that Phantom Grip cheater system??A friend of mine uses it in his 93 JRSC Civic and seems to work out alright plus he said it's wasn't as bad to install compared to LSD unit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveAHonda »</TD></TR><TR><TD CLASS="quote">hold on so i cant use a stock prelude lsd in my h22 tranny???</TD></TR></TABLE>
I've heard 1 report of this working, but it was from a guy up at Auto-X (who really knows his **** but I still question if this is true). He said somehad had used a OEM LSD in a SH tranny... no clue if the car was a base or what. Would this be possible? Is the SH housing bigger than the base (i'd assume because of the ATTS stuff), and is it large enough to hold the OEM LSD?
You can't use a JDM OEM LSD in your USDM trans, it won't fit cause it's way too huge.. I tried, nah uh. You can use an entire JDM trans with an LSD, no prob, I am and I've loved it ever since I first put it on my lude. Heh, use it all the time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveAHonda »</TD></TR><TR><TD CLASS="quote">so what about this phantom grip, i have seenit but didnt think it ever worked</TD></TR></TABLE>
I have only heard bad things about the phantom grip but only good things about the quaife LSD, but its more expensive.
Knightzero7
Transmission & Drivetrain
Apr 10, 2014 02:39 PM
Big Poppa Pump
Oct 5, 2003 07:58 PM
