Will p30 b16 Pistons hit my LS valves???? Helppppp
Old Sep 5, 2003 | 12:44 PM
JLange's Avatar
Default Will p30 b16 Pistons hit my LS valves???? Helppppp
I plan on putting in some p30 pistons in my LS, someone said that if i just do that, the p30 pistons will hit my valves, is this true or not?
Old Sep 5, 2003 | 02:46 PM
civicVX's Avatar
Default Re: Will p30 b16 Pistons hit my LS valves???? Helppppp (jtintegra)
you can always clay the motor before you completely put it back together
Old Sep 5, 2003 | 03:08 PM
skribblah's Avatar
Default Re: Will p30 b16 Pistons hit my LS valves???? Helppppp (civicVX)
i told him that he wont listen... he wants to hear it from somebody that it will work.
Old Sep 5, 2003 | 03:50 PM
fox297's Avatar
Default Re: Will p30 b16 Pistons hit my LS valves???? Helppppp (skribblah)
I'm currently running CTR in my LS. It seems to work fine!
Old Sep 6, 2003 | 09:21 PM
yeer's Avatar
Default Re: Will p30 b16 Pistons hit my LS valves???? Helppppp (fox297)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox297 &raquo;</TD></TR><TR><TD CLASS="quote">I'm currently running CTR in my LS. It seems to work fine!</TD></TR></TABLE>
u shouldnt have a problem. if hes running CTR in his ls then p30 will be fine. ill be running the p30s myself in a ITR block when i start my rebuild in 2 weeks.
compare the ctrs with p30s side by side, u can tell that the ctrs are higher.
Old Sep 6, 2003 | 10:39 PM
function83's Avatar
Default Re: Will p30 b16 Pistons hit my LS valves???? Helppppp (yeer)
if you plan on revvin it above 8 grand. invest in some apr rod bolts.
since stock ones tend to stretch in sustained revs above stock limit.
Old Sep 28, 2003 | 09:38 PM
wm5holla's Avatar
Default Re: Will p30 b16 Pistons hit my LS valves???? Helppppp (djhatch)
i know to know to !
Old Sep 29, 2003 | 07:18 AM
JLange's Avatar
Default Re: Will p30 b16 Pistons hit my LS valves???? Helppppp (wm5holla)
what?
Old Sep 29, 2003 | 07:27 AM
advanracing62's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">i know to know to !</TD></TR></TABLE>
I thought this was answered farther up in the post
Old Sep 29, 2003 | 11:58 AM
JLange's Avatar
Default Re: Will p30 b16 Pistons hit my LS valves???? Helppppp (advanracing62)
well my car is running with p30s in there
Old Oct 5, 2003 | 04:11 PM
99lsvtecauto's Avatar
so me make sure i can got this right u take take ls rods and wrist pins and connecting them to b16 pistons and they will work without any modifications to the engine block . these would just b regular b16 piston not over bore right will overbore need to have block honed 2 make them fit
Old Oct 30, 2003 | 12:52 PM
insane_integra's Avatar
thats right
bOOsT-FeIn
Oct 30, 2006 07:55 PM
2uy
Sep 14, 2005 02:42 PM
arw321
May 9, 2003 03:12 AM
HKxGroggy
Oct 30, 2001 03:42 PM
