Brake light on cluster coming on again
Old Sep 5, 2003 | 12:11 PM
senjen69's Avatar
Default Brake light on cluster coming on again
I already changed the tail lights and checked the fluid levels, all okay but the dash brake light still comes on. WTF is wrong with my whip! I'm going to start losing interest in the Prelude and get an Infinity!
Old Sep 5, 2003 | 01:06 PM
weakGOODJunKieS.com's Avatar
Default Re: Brake light on cluster coming on again (senjen69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senjen69 &raquo;</TD></TR><TR><TD CLASS="quote">I already changed the tail lights and checked the fluid levels, all okay but the dash brake light still comes on. WTF is wrong with my whip! I'm going to start losing interest in the Prelude and get an Infinity!</TD></TR></TABLE>
did u fill the fluid up to the line?
Old Sep 5, 2003 | 01:26 PM
phildeez's Avatar
Default Re: Brake light on cluster coming on again (FrostWhiteDC4)
check the brake bulb again...the brake bulb has two filaments....one for when you turn your lights on and the other for when you actually step on the brake pedal...if one of the filaments burn out then the cluster light will come on.
also if you changed the bulb...make sure you got the right bulb...look at the bottom of the bulb and it should have two solder marks.
oscarlx
Jul 1, 2012 08:54 PM
SpazMan
Jun 22, 2009 08:44 PM
93civciv
Mar 5, 2006 06:02 PM
Draggin99Si
23
Feb 14, 2005 01:04 PM
ilikemyaccord
Jun 13, 2004 09:16 PM
