b18b in crx, throws of balance?
Old Sep 5, 2003 | 10:49 AM
p1ccoloz's Avatar
Default b18b in crx, throws of balance?
Does the extra weight of the b18b offset the balance much? Looking into building a crx/b18b for autoX, is the crx recommended? Thanks for imput! (searched already)
Old Sep 5, 2003 | 10:56 AM
dra600n's Avatar
Default Re: b18b in crx, throws of balance? (p1ccoloz)
I believe that you will need some extra springs/coil overs (or stronger ones) since the engine will weigh down the front end quite a bit, like, literally dragging on the ground. The B16a and B18's are nearly 2 to 3 times the weight of the stock crx engine from what I understand, so you will need to do something to give the body enough strength to support it.
Old Sep 5, 2003 | 12:20 PM
tpr's Avatar
tpr
I do not have hard number but 2X or 3X as heavy. Not likely! Yes it will affect balance but what that will do to handling????? I don't know!
Old Sep 5, 2003 | 03:15 PM
APEX CRX's Avatar
sorry but I never heard the b series motors weighing 2 to 3 times the d series motors. i thought maybe 100 lbs is a good guess. basically hybrids have been pretty well thought out now. Progress even makes a special set of lowering springs just for hybrids. Regarding handling the more weight in front the more you understeer
Old Sep 5, 2003 | 03:31 PM
roadawg's Avatar
Default Re: b18b in crx, throws of balance? (dra600n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dra600n &raquo;</TD></TR><TR><TD CLASS="quote">I believe that you will need some extra springs/coil overs (or stronger ones) since the engine will weigh down the front end quite a bit, like, literally dragging on the ground. The B16a and B18's are nearly 2 to 3 times the weight of the stock crx engine from what I understand, so you will need to do something to give the body enough strength to support it.</TD></TR></TABLE>
Jeez, think about what you stated.
Let's say a stock D series engine weighs 350 lbs, all accesseries included.
Now a b16 is only .1 liter bigger but according to you it weighs 750 to 1,000 lbs
Can you guys say nooooob!!!!
bubbabns
Dec 22, 2011 07:59 AM
dazxguy
Apr 1, 2004 10:55 AM
