How do you know if your clutch is slipping?
Old Aug 18, 2001 | 06:19 PM
teq1816's Avatar
Default How do you know if your clutch is slipping?
What does it mean when your clutch releases at the last second? Is it dying? It still accelerates as normal even under heavy throttle. It is NOT revving up and not moving, it just feels weird as it didn't use to do that. By the way, its a stage 3 clutchmasters w/ flywheel. TIA.
Old Aug 18, 2001 | 06:29 PM
DragII's Avatar
25 Year Member
Default Re: How do you know if your clutch is slipping? (teq1816)
if it slips revs go up but you don't accelerate...no other way to describe it
Old Aug 19, 2001 | 12:35 AM
samdawgsol's Avatar
New User
I dont have experience with what you are talking about so ill just give some advice. Make sure the throttle cable in the engine is where it is supposed to be. I mean check to make sure there is no shiny metal on the cable, meaning it has recnetly been exposed. Also, make sure the cable to the clutch pedal is secure and tight. Ive had a cable from the gas pedal pop out loose once b4. If that dont work, go to someone who REALLY knows what their talking bout.
anyways, good luck
Old Aug 19, 2001 | 07:54 AM
advanracing62's Avatar
Default Re: How do you know if your clutch is slipping? (samdawgsol)
basically you release your clutch and you don't go anywhere... all you do is rev the engine. You'll know it when it happens.
kid_02131
12
Nov 6, 2013 05:32 AM
1320king
13
Apr 19, 2008 12:33 PM
ThaMatrix
Jun 7, 2005 03:15 PM
InJ3cted
May 24, 2005 02:16 PM
