trailing arms rear disk brake conversion?
Old Sep 5, 2003 | 09:29 AM
Slvr_CRX's Avatar
Default trailing arms rear disk brake conversion?
I have the parts to do the conversion but i notice that i cant turn the rotor and that the cailibers are closed. does that mean its broke? or if i hook em up they will work again? please let me know.
Old Sep 5, 2003 | 09:33 AM
TomO's Avatar
good thing to do would be to rebuild the calipers before you put them on the car. The rebuild kits are cheap, and easy to do. They are basically the grommets for the caliper. you just replace them , re grease everything and you are good to go.
Old Sep 5, 2003 | 10:42 AM
raene's Avatar
Default Re: (SonicGSR98)
I hate rebuild kits with a passion... buying a pre-rebuilt caliper is cheap insurance IMO! I tried doing the kit, fugged it up, and went and bought rebuilt calipers.
Old Sep 5, 2003 | 05:41 PM
jimbob_racing's Avatar
Default Re: trailing arms rear disk brake conversion? (Slvr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slvr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">I have the parts to do the conversion but i notice that i cant turn the rotor and that the cailibers are closed. does that mean its broke? or if i hook em up they will work again? please let me know.
I had the same problem when I converted my '88 CRX over to discs. The arms were outside in the junkyard for a while and the rotors and calipers were toast. I bought new Brembo rotors and rebuilt calipers from Advance Auto and installed them before I did the swap. Easy and done for years to come.
FGride
May 25, 2006 12:46 PM
Project X
Feb 25, 2004 08:20 AM
brian2903
Nov 25, 2003 12:39 PM
precord96
Sep 9, 2003 08:05 AM
JDMACCORD
Feb 12, 2002 09:11 PM
