Type-R VTEC solenoid.
Old Sep 5, 2003 | 09:07 AM
dunkd's Avatar
Default Type-R VTEC solenoid.
any of you guys with type-r's can i see a pic of your vtec solenoids? i bought my gsr swap and now im just finishing up putting it all together, some of the parts that the kid gave me weren't for a gsr, but a type-r i believe. first of all he gave me an obd2 distributer with the 94/95 gsr, spliced a few wires and that was fine... the next thing is the vtec solenoid. it have no plug for the vtec oil pressure switch, so i went to honda and talked to one of their mechanic's and he told me that my vtec solenoid was off a type-r, maybe jdm... are they the same jdm and usdm? my vtec solenoid looks like a normal one except for where the oil pressure plug is there is nothing, just a depression in the solenoid...
Old Sep 5, 2003 | 06:19 PM
dunkd's Avatar
bump
Old Sep 5, 2003 | 07:29 PM
len's Avatar
len
Default Re: Type-R VTEC solenoid. (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">my vtec solenoid looks like a normal one except for where the oil pressure plug is there is nothing, just a depression in the solenoid...</TD></TR></TABLE>
I have the same problem. No VTEC=(
Item 15 is the switch with 25 as the o-ring.
Give me a call with what you need.
Old Sep 5, 2003 | 09:04 PM
markpaco's Avatar
you have a JDM VTEC solenoid. The JDM motors don't use the sensor you are missing. You may either have to swap it for a USDM one or run a JDM ECU if you aren't already.
Old Sep 5, 2003 | 09:18 PM
dunkd's Avatar
Default Re: Type-R VTEC solenoid. (markpaco)
so its a jdm itr solenoid? or are all jdm solenoids like this, no oil pressure switch...
Old Sep 5, 2003 | 09:28 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
both of my JDM heads were blocked off, and had no oil pressure switch at v-tec solenoid.
Old Sep 6, 2003 | 06:31 AM
Ausmith's Avatar
Yes.
You have a few options:
1)Run a JDM ECU
2)Run Hondata where you can remove that switch
3)Get a USDM VTEC solenoid and run a US ECU
4)You can "short" that circuit out and fool the ECU
Old Sep 6, 2003 | 11:38 AM
LeftCorner's Avatar
Default Re: Type-R VTEC solenoid. (Ausmith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ausmith &raquo;</TD></TR><TR><TD CLASS="quote">You have a few options:
1)Run a JDM ECU
</TD></TR></TABLE>Or use a VAFC since it disables the press. switch. I used the JDM spool valve when I had my VAFC - looked nicer!
Old Sep 6, 2003 | 11:43 AM
1GreyTeg's Avatar
Default Re: Type-R VTEC solenoid. (len)
Whats the advantage or disadvantage to having the switch or not having it?
Why would the JDM motor not have it and vice versa witht he USDM?
Old Sep 6, 2003 | 05:12 PM
Ausmith's Avatar
Default Re: Type-R VTEC solenoid. (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Whats the advantage or disadvantage to having the switch or not having it?
It's JDM yo!
Old Sep 6, 2003 | 05:14 PM
Bbasso's Avatar
Default Re: Type-R VTEC solenoid. (LeftCorner)
"I used the JDM spool valve when I had my VAFC - looked nicer! "
Got a pic for us to see?
Old Sep 6, 2003 | 05:19 PM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">
Give me a call with what you need. </TD></TR></TABLE>
Bahahhahah len..bahhaahah
Old Sep 6, 2003 | 07:43 PM
dunkd's Avatar
hey anyone want to buy this JDM vtec solenoid? get the "JDM" look... make an offer.
Old Sep 6, 2003 | 08:38 PM
Tweakmeister's Avatar
Default Re: Type-R VTEC solenoid. (ragejed)
so it makes Vtec kick in without checking for pressure?!?
Old Sep 6, 2003 | 08:50 PM
v-attack's Avatar
Yeah I got one for sale two, comes with two JDM heads
Old Sep 7, 2003 | 07:53 AM
dunkd's Avatar
it is monitored elsewhere.
Old Sep 10, 2003 | 10:48 AM
Darkteg's Avatar
New User
Default Re: (dunkd)
Euro Rs don't have it also, Kenji had to fool my usdm p28 ecu on the harness. ask him!
Old Sep 10, 2003 | 09:28 PM
MissMyHonda's Avatar
The VTEC Oil Pressure switch is there simply for stupid americans who tend to beat on the car before it's warmed up. Go find the huge nerd ECU boards they can help you with chipping a USDM ECU so it wont throw the code. It's a non-tuning code anyway (doesn't affect the A/F ratio or timing)...There's no need to have it so long as you allow the motor to warm up before revving high.
Dead CIVIC
Jul 14, 2008 02:01 AM
ekb16
Oct 19, 2005 11:25 PM
SLOW4drINTEG
May 5, 2003 10:47 PM
Timmayeg
Mar 5, 2003 09:25 PM
