anyone take a door off?
Old Sep 5, 2003 | 07:26 AM
igo4bmx's Avatar
Default anyone take a door off?
and if so. is it hard? any concerns?
Old Sep 5, 2003 | 07:39 AM
civickidd99's Avatar
Default Re: anyone take a door off? (igo4bmx)
Itook them off my crx and it wasn't too hard. I did it alone so i HAD to use a jack under the door, but it's really pretty straight forward. hope this helps.
Old Sep 5, 2003 | 08:51 AM
rodrez.'s Avatar
Not too hard, disconnect the harness if you have power windows/lock, tap the pin out, and unbolt them, that's it.
Old Sep 5, 2003 | 09:01 AM
DXturbo's Avatar
Default Re: anyone take a door off? (civickidd99)
why are you taking the doors off? anyways... just mark it so you know where to put it back on. it gets hard to align sometimes..
Old Sep 5, 2003 | 09:02 AM
igo4bmx's Avatar
Default Re: anyone take a door off? (DXturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DXturbo &raquo;</TD></TR><TR><TD CLASS="quote">why are you taking the doors off? anyways... just mark it so you know where to put it back on. it gets hard to align sometimes..</TD></TR></TABLE>
the reason is because i was wiring new speaker wire to handle higher power for my front speakers, and i think i fuct up the wire harness when i drilled into them
Old Sep 5, 2003 | 09:33 AM
igo4bmx's Avatar
Default Re: anyone take a door off? (Kikomon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kikomon &raquo;</TD></TR><TR><TD CLASS="quote">why not just the door panel?</TD></TR></TABLE>
well its extremely has to get to the area im trying to get tol..
its bwteen the dor and the body of the car (door jam)
i think i royally fuct up the wiring there so i need to pull out the harness, pull the pins out and make sure each wire is intact
Old Sep 5, 2003 | 09:37 AM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">
i think i royally fuct up the wiring there so i need to pull out the harness, pull the pins out and make sure each wire is intact</TD></TR></TABLE>
Just pop the pin out and the door will swing open even more, but leave it the bolts on. That should give you plenty of clearance for the inside jam to fish some wire through.
Old Sep 5, 2003 | 09:50 AM
igo4bmx's Avatar
Default Re: anyone take a door off? (Newman)
Old Sep 6, 2003 | 11:34 AM
igo4bmx's Avatar
do you know where the pin is??
i'm not too sure
Old Sep 6, 2003 | 11:35 AM
rodrez.'s Avatar
When you open the door, you'll see it in the middle of that flat metal bracket.
clem kevin
Dec 20, 2006 06:41 PM
JDM*addiction
21
Jul 28, 2006 09:11 PM
flekz
Dec 29, 2005 05:49 PM
Ekay Jay
Sep 16, 2005 05:07 AM
2lua
Dec 3, 2003 09:02 PM
