Trunk mounted batteries?Do they require a external cutoff switch to pass tech inspection at the trac
Old Sep 5, 2003 | 06:25 AM
MikeySpec's Avatar
Default Trunk mounted batteries?Do they require a external cutoff switch to pass tech inspection at the trac
I have my battery mounted in the trunk of my 89 CRX Si.I did it with a complete sealed kit from one of those v8 companies.its got a nice box for it,nice gauge wire,fuse cutoff..etc..etc.But i heard rumor's that i wont be able to run at the track unless i had a cutoff switch put on the rear of the car?How true is that?
Mikey
Old Sep 5, 2003 | 06:26 AM
Jared's Avatar
Default Re: Trunk mounted batteries?Do they require a external cutoff switch to pass tech inspection at the
In most sanctioning bodies, any car with a relocated battery requires a cutoff switch.
Old Sep 5, 2003 | 08:23 AM
1fstevo's Avatar
New User
yep, I have been warned to get the cut off switch installed every damn race this season and I finally installed it recently.
Old Sep 5, 2003 | 08:53 AM
T4eg's Avatar
yes, you will need a cut off swtich
t66crx
May 6, 2012 07:58 PM
charlie_sohc
Apr 5, 2006 04:53 PM
civeek
Mar 5, 2006 09:48 AM
