clutch problem...comes and goes...confused
Ok i have no clue whats going on with my clutch. First time this happened i was almost completely out of fluid, 2nd time had plenty of fluid but clutch was enganging right off the floor so i blead it and it was fine for a week. Now it happend again and have plenty of fluid so i bleed it once again. still same thing happens clutch is enganging just off the floor. Then all of a sudden clutch is fine and grabs about halfway. I also have pedal pressure the whole way instead of only halfway.
Sounds like well the shaft were the disc rides is sticking probly was not cleaned and greased properly. Sounds like some cars if worked on before.
If you're going to the trouble to replace the master cylinder (which is most likely part of the problem--they all leak) go ahead and do the slave cylinder too...that way you won't have to screw with it again...
Good luck!
Good luck!
i got a new master cylinder but havn't changed it yet. I still having the trouble but it goes away when i drive the car. If the car sits for like a few hrs the clutch enganges right off the floor.
check the clutch fluid lines all the way to the tranny from the resivor. and make sure they are tight.
I had the same problem, and it was caused from my friend not tightening the clutch lines where it attached to the rubber hose just off the slave cyl.
