Question about a camber kit install for 96-00 civic
Old Sep 5, 2003 | 05:32 AM
soundbomber's Avatar
Default Question about a camber kit install for 96-00 civic
Hi, any of you guys who have done this, it would be a great step forward for me if you could point me in the right direction. Basically, i'm wondering about the bushings at the end of the arm towards the chassis side. Looking at pictures of the stock upper arm in my haynes I can see that it has bolts on it already. The ingalls front kit that i have does not have this type of thing. It has bushings with a hole in it and i'm wondering if i'm supposed to integrate the bushings off the old upper arm into the ingalls upper arm? Thanks.
Old Sep 5, 2003 | 06:39 AM
Crazydave's Avatar
Default Re: Question about a camber kit install for 96-00 civic (soundbomber)
When I got the ingalls for my car.. it had the bushings. everything bolted right up.
the bolt goes through the chassis through the bushing and back into the chassis again
Old Sep 5, 2003 | 09:31 AM
so you're saying there's a bolt that goes through the bushing on the camber kit back into the chassis? if so, thanks for your help. this is for the front btw. I was just wondering because on the stock upper arm for the civic, the bolts that goe through the chassis form a 90 degree angle with the arm and on the ingalls, it's just 2 bushings that are perpendicular to the chassis.
Marauder
Suspension & Brakes
Jan 13, 2009 07:41 AM
nfinitecc
Feb 24, 2005 07:35 AM
Thrillhouse
Aug 9, 2003 01:53 PM
1bar
Aug 21, 2002 04:06 PM
