Installing a front sway bar
I was thinking of getting the Suspension technique front and rear sway bar set for my 97 civic hatch. Since my car doesn't have a front sway bar how difficult will it be for me to install the ST front sway. I read somewhere that you have to take off the mid section exhaust pipe to get the bar on. If so is there any way not takeing off the mid pipe to put the sway on.
PS. When I get the Suspension Technique sway bar set I'm just going to install the front sway. I'm going to get the Comptech rear sway and tie bar combo so I might be selling the ST rear sway bar with the endlinks.
there are two versions the st makes one for a car with sway bars and one for cars without swaybars get the one without and it should come with everything to install
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 »</TD></TR><TR><TD CLASS="quote">i believe you gotta take them out, but if it too much work for you just dont do it cause you might break a nail or something</TD></TR></TABLE>
ouch. just do the install its easy
Andrew 825SM
Jul 7, 2003 01:19 PM
